Everything about the iPhone X
ragnarok95
Senior Moderator
Senior Moderator
Anyway, iOS 11 is indeed buggy and lots of apps have yet to support iPhone X. May not have the best experience now but will get better.
By the time you get the best experience, it's time to de-com this X and go for the bigger version of it. :s13:
szeli
8am 98% battery life. Use FB, Safari, checked emails, WhatsApp, one call & now left 85%. Background app refresh off for all except whatsapp. Is it normal for the battery to drain so fast?
is that fast draining? calculate backwards it seems like u can get 7+hrs of usage. isn't that normal?
aztech44
Then is this normal? Since 6.30am (100%)
swch819
mkv
hi guys any idea of any apps to put mkv files into the phone? most of the app is either not updated for the x yet or filled with ads
ragnarok95
Senior Moderator
Senior Moderator
Personally i think its not just about space gray. As silver is also prone to scratches, bottom line. Use casing to prevent such things happened for both colours
No. Silver even if you scratch, it's still silver. The space grey is a coating, so if you scratch, you will see silver.
VodkaPear
No. Use case also will scratch caused by dust stuck in between. That's stainless steel.
But light scratches on silver can be polished off. Space gray can only LLST.
Thus, I think I will refund my sg take white. :s22:
aztech44
Yup its true, that silver scratches can be polish off and space geay can LLST. But if you read the articles properly. It stated that the coating peeled off due to owner decide to use without cases . And it look like the phone dropped very badly or otherwise.
No matter what colour is your phone, if you the owner took care of things really well, i dont see this happening to your phone though. :)
