iPhone X problems faced
Nwadkh
Hi. Anyone realised their screen will flicker when going through gallery or emails?
klho001
Recently purchased the mophie wireless charging base too and charge my X everyday, and all the time goes to 100%, no issues.
Might be a faulty wireless charging unit? It has 2 years warranty though.
Anyway beauty of buying from Apple online i just a phone call and ask for a replacement and it's on the way! no harm trying another charger.
Snoweagle
Some more there’s the 14-day return policy, which is also reflected in the e-receipt they send to your e-mail.
mauiheng
Not sure if you guys play Pokémon Go on iPhone X. I seems to have the problem of GPS Not detecting errors. My iPhone 7 Plus, the game works smoothly.
xhui22
Yes.. mine as bad. GPS drift, caused me some raid pass and frustrations.. sigh.
Snoweagle
Mine’s fine, unless playing indoors then will turn on wifi for mapping.
gardiboy
An update is already in progress by Niantic and it will supoirt the iPhone X
I am too receciving alot of GPS errors
ragnarok95
Senior Moderator
Senior Moderator
NN gps errors only occur on latest iphone. Basically 8, 8+, X all have the same issue. If you on power saving mode, gps won’t be able to detect and you can’t move. No issue whatsoever with iPhone 7.
disastrous
Saw someone on the train playing Pokemon and he was terminating and re-launching the app every 20 secs. Tot he using some hack. So is GPS problem lol.
mauiheng
Ok thanks! It is really the power saving mode. I switched it off and the game seems ok for now.
