Nokia
Ed.YEO
Which one you've gotten?
At which store, and at what sort of price & warranty terms.
Thank you. And please do give a short review of your new device.
$225,橙铜背壳出口機,無保修。Mustafa 買。
一番屋企,连接網絡,無5分鐘就开始提示系统提升。。。好似Windows電脑咁,由出廠日期开始慢慢地一段一段慢慢叫你重新启動手機更新。7.1 至 7.1.1 至 7.1.2。。。成個系统更新無晒幾個鐘,係做唔到嘅。。。
最新更新係十月安全套包,7.1.2。
未見到摄影功能有lumia操作更新。
K202020K
最新更新係十月安全套包,7.1.2。
未見到摄影功能有lumia操作更新。
Thanks for the update.
Should be the Nokia 5 model with NFC feature. Good choice, only setback is the SD430 processor is not 4G/3G ready. So the second SIM slot can only run 2G network.
derrick__
Just curious, is there any service centre for Nokia phones in Singapore?? Visited the site but indicates no service centre in Singapore, only over the causeway...
marcoyeo
I did a Google search it says, Nokia Pte Ltd is located at:
438B Alexandra Rd
#08-07/10 Alexandra Technopark
Singapore 119968
Tell: +65 6551 6000
I think best to give them a call before going down.
K202020K
Maybe it's the office of the defunct Finnish Nokia. Not the new Taiwanese Nokia under HMD Global.
marcoyeo
Just got my set. Power on the device, connected to WiFi, and received the Oreo update direct. :love:
Pocoyoz
Nokia's first new smartphone to launch in early 2018 may in fact be a new Nokia 6. That makes sense since the original was the first device put out by HMD Global, as it became official this January.
The upcoming Nokia 6 (2018) has been certified by TENAA in China, a mandatory step for any handset that wants to be sold over there. Unfortunately, at this stage in the process TENAA hasn't yet made images and specs available for the new model.
Going by past leaks, however, we should expect to see a 5.5-inch 18:9 touchscreen, the Snapdragon 630 SoC at the helm, 4GB of RAM, 32GB of storage, and a possible dual rear camera setup. The fingerprint sensor will move to the back, which hopefully means the bezels will undergo a trimming. The device will also sport software-rendered Android navigation buttons, while the Bothie feature isn't going anywhere.
The phone's model number is TA-1054, and it will have a dual-SIM version. Its design will apparently be reminiscent of the recently announced Nokia 7. So it looks like 2018 may be the year in which HMD Global finally gets on the 'tall display, small bezels' bandwagon.
Sent from Pocoyo fan club using GAGT
Ed.YEO
之前無估錯,nokia6 降价也者意味緊水貨嘅來临。。。。。。nokia6(2017) 行貨已經到啦!!!
宜家可以喺你地所知嘅手機鋪買到啦!价格介於$275至295之間,祇有黑,蓝,两色選擇。3gb記忆體,32gb内存。
jeffrey745
Pls post in English instead, thanks.
