Oneplus 5T
Sauron
You did it yourself? How did u remove the factory protector?I already bought it but I got phobia. Last time I did myself, so many bubbles.
Just use nails to lift off the factory protector.
The tempered glass was quite difficult to apply perfectly. Took me 3 times and still not centered. But manage to remove all bubbles.
Had no problems applying tempered glass on other phones but first time applying a tempered glass that fully covers the screen
imacbie
where u git the tpgs from? sic link?
unknownfame
I also used the tempered glass, seems like it crops off the edges from the phone display. Is it like that for you also?
sunht
My friend will come from HK, can I check with you guys who has experience.
They need to hand carry the phone when taking flight. So when my friend go through the security check, they have to take new phone out right? Need to unseal the box or not?
I want to make sure security won't give them too many trouble.
Thanks in advance.
bawawaw
Thanks in advance.
If you're going to use it, might as well ask your friend to open it. Put the box in checkin, then the phone in hand carry.
Don't think they will ask it if it's only one phone.
Skyy
Thanks in advance.
actually what's your reason for buying hk sets instead of buying from qoo10? cos buying on oneplus's website with your local credit card will be subjected to crappy exchange rates and maybe even other admin fees. whereas if u buy from qoo10 u can max out your credit card cashback, use their gift card vouchers for added discount and have shopback rebates too.
jtec14
Those that have hooted? Enjoying your OP5T?
Coming from 3T, awesome upgrade! :)
I think the cameras are good, maybe I am not a photo person since I can accept 3T photos as well. The thing is for oneplus phones, you need to have a pair of steady hands but even with a pair of not so steady hands like mine, I think I still can take acceptable pictures with 3T and 5T. =:p
No complaints for oxygen OS, still as snappy. Bigger screen as well, can't keep my hands off the phone. :s13:
Worth the buy for me!
rollanddie
Those who have bought cases and tampered glass sp, please do share here! :o
Sent from 1000char using GAGT
