[SIC] Hoot Club! Post Your Technology/Hardware Related Purchases Here! - Part 4
Elijahonli
time to sell i supposed.
but actually i got it with the intention to replace the old DAC as it was too big but looks like no i have no choice and unless there is a way to get my speakers to connect to 2 different inputs LOL ?
Does 3.5mm splitter affect audio performance? haha
Edit: googled and it was recommended not to use 3.5mm splitter to feed 2 audio source the speaker LOL
so i need RCA splitter lol
hlots123
I have been playing Battlefront 2 extensively last night and it is smooth as butter. Getting around 100-134fps on Ultra settings in game. PERFECT.
juz asking, for ur competitive play its better for u to have higher fps >120 with chance of tear, than keeping within gsync limit & no tear?
elmariachi
Actually, using the option FAST under Vsync in nvidia control panel, even more than >120fps I have not encountered any tear. Keeping it around 100-120 is very smooth even dipping below 100s still smooth. Can only tell not very smooth when it drops below 90. At least with Battlefront 2. Battlefront 2 game play is slower so the occurrence of tearing is not as high as Battlefront 1.
I tried Battlefront 1 to compare and the max I get is around 140fps and there is slight tearing when I snatch my wrist when making fast movements. But it is the same as when I had my S2716DG 144hz when I was getting about 170fps on 2560x1440.
So all in all, actually works better keeping within G-sync range with Vsync set to Fast in nvidia control panel.
Nakedtoes
Latest movies usually shot in 21:9 so perfect for an Ultrawide.
Games that support 21:9 looks great!
I have been gaming on it for hours on end and never gave me a headache.
The curve makes it more immersive.
Note: This is not alienware or acer but still a 34" curved ultrawide that is about $850.
Full HD only right? What model?
hlots123
oic, but see if jorimt's diagram & post helps in any way...
https://forums.geforce.com/default/.../gsync-not-working-100-/post/5016644/#5016644
oops i forgot to add link jus now
elmariachi
hlots123
My understanding of fast sync must be wrong then if referring to the diagram. Right now basically I am getting between 100-130fps on ultra settings, it can go down to low 90s or high 80s depending on which map.
So question is should I use Vsync on now?
i believe his recommendatns are:
gsync ON
nvcp vsync ON (game vsync OFF)
frame limiter set a few frames below max/120
for frame limiter u can try if RTSS (afterburner) better, or in-game better
i believe he said there are some games, the in-game limiter is bad?
as u kno, i'm not sensitive so i jus use RTSS to keep it simple
elmariachi
gsync ON
I will try it tonight and see how it goes.
Wah hlots eveytime you post, i research untill siao but in the end things work out for better. You GURU!!!
CrispyPeddler
gsync ON
hmm.. i dont understand on the frame limiter part based on the diagram.
currently my setting is
Gsync on
Vsync on (nvcp), Vsync off (in-game)
no frame limiter or anything.
so, with my current setup, i shud set RTSS frame limiter at 144fps (since my monitor is OC to 165hz) to optimize my gsync in any game? :s22::s22:. teach me GURU! i have not until now see any difference by using gsync.
elmariachi
Gsync on
I was just reading a whole bunch of mambo jumbo and I think optimal G-sync settings from what many people are saying is :
Optimal G-SYNC Settings*
*Settings tested with a single G-SYNC display on a single desktop GPU system; specific DSR, SLI, and multi-monitor behaviors, as well as laptop G-SYNC implementation, may vary.
Nvidia Control Panel Settings:
  • Set up G-SYNC > Enable G-SYNC > Enable G-SYNC for full screen mode.
  • Manage 3D settings > Vertical sync > On.
In-game Settings:
  • Use “Fullscreen” or “Exclusive Fullscreen” mode (some games do not offer this option, or label borderless windowed as fullscreen).
  • Disable all available “Vertical Sync,” “V-SYNC” and “Triple Buffering” options.
  • If an in-game or config file FPS limiter is available, and framerate exceeds refresh rate:
    Set 3 FPS limit below display’s maximum refresh rate (57 FPS @60Hz, 97 FPS @100Hz, 117 FPS @120Hz, 141 FPS @144Hz, etc).
RTSS Settings:
  • If an in-game or config file FPS limiter is not available and framerate exceeds refresh rate:
    Set 3 FPS limit below display’s maximum refresh rate (see G-SYNC 101: External FPS Limiters HOWTO).
I will try it tonight and see. I think best to use in-game Frame Limiters if possible otherwise use RTSS and minus 3 frames from your refresh rate for the FPS cap. I know Battlefront has ingame commands you can use to frame cap. I also never used a frame cap untill now but I will try with those settings and see if it is any smoother.
hlots123
paiseh, no lah
actually i jus use wat expert say w/o actually comparing
but since ur extra sensitive & competitive, u shd see which better
and jorimt actually mentioned this further down,
If you're not noticing tearing, and would rather get all the frames you can outside the G-Sync range, then just leave it as is. You're one of the few people G-Sync on + V-Sync off was intended for; you don't even need an fps cap.
With G-Sync on + V-Sync off + no fps cap, you're getting the least input latency possible.
hlots123
Gsync on
i rem jorimt ever said gsync just set RTSS limiter 2-3 frames below max & call it a day (orange range) - for no tearing
but some pple mention they still get tearing in that range
and tats where the green range & explanation come in
^ be aware my understanding may not be correct, as i glanced thru many posts & threads back & forth to get an overall gist when i bot my gsync monitor...
Encrypted11
When hlots makes a post, will look back and most will think how come I couldn't find it on google earlier on :s34:
elmariachi
I still think it is far better to use in-game limiters if possible unless the game does not have an inbuilt frame limiter, the use RTSS.
CrispyPeddler
irregardless of what my ingame fps, i just set all games (if there is no ingame frame limiter) with RTSS 2-3 frames below my monitor max fps?
hlots123
hmm i think ur correct, seems jorimt mentioned in-game limiter best
https://www.blurbusters.com/gsync/gsync101-input-lag-tests-and-settings/11/
i think i mixed up wat jorimt posted & RealNC posted, & who said wat exactly - sorry abt for any misinfo earlier
https://forums.guru3d.com/threads/the-truth-about-pre-rendering-0.365860/page-18#post-5475016
https://forums.guru3d.com/threads/the-truth-about-pre-rendering-0.365860/page-12#post-5380262
edit, added more links
hlots123
popeyes
ya.i had the promo code now. I am wondering 300 off is based on 2199 or 1799. I have no luck to get thru Dell plaza singapura, nobody is picking the phone.
It's $1799 minus $300 thus final price $1499. I called and the dell guy said can assist me to purchase over the phone, i was like :eek:
Anyway he said there's a display set at Dell Plaza sing so those interested can pop by.
