GPU brace / support
Coool11
My gpu sagged alittle, thought of using a support. Anyone using this? Any good? Or are there better support available in SG?
elmariachi
The type you posted above does not really work for one reason. The sag is towards the end of the card and the length of the support by the time it reaches the end won't do anything for support.
There is another kind of GPU support like the one below that will work much better. My take is that if your GPU is sagging minimally, leave it. If it is bad, then get it supported.
I see that you are having a Gaming X 1080 Ti. That card seriously does not need a GPU support. It is far smaller and shorter than most 1080 Ti's in the market.
ESLOTH-Cooling-Graphics-Card-Holder-Jack-Bracket-Desktop-Computer-Video-Card-Companion-Support-Graphics-Support-Cold.jpg_220x220.jpg
Coool11
Cool. Thank you for advise. It is really not sagging alot and if the cost doesn't justify, i will just leave it as it is and go for a few can of beers.
Psycovirus
A quick way to fix Sag. I used the add-in extra screw at back of the slot to prevent GPU sag and it was fixed. Do note, not all GPU will work...
Sent from OnePlus ONEPLUS A3000 using GAGT
