Can i know what ceiling fan you using? Looking for RF fan but most of them are IRThank you will check it out!
My main concern is to control the ceiling fan using RF.
Sent from Samsung SM-G935F using GAGT
Anyone using Somfy’s TUBE NC50 Curtain Motor? Able to hook it up with any hub and alexa?
According to Somfy, tube nc50 is not compatible with mylink
I think it needs to use a rts to zwave converter...
Hi folks, do you have electrician to recommended for neutral line wiring? Probably can sub my whole house electrical work to him too. Spoken to few ID and they totally have no idea on HA.
PM me please, TIA!
I am a newbie.
1. My room have a table fanhttps://www.kdk.sg/a40as.html
2. Normal hdb bedroom ceiling light wall on/off switch how to set it turn off on at certain time?
3. Tv plug power switch on/off how to set it turn off on at certain time?
4. If all the above cannot set time to turn off/on, how to use app to turn off/on if I am not at home?
Thanks
PM me please, TIA!
They don't need to know anything about home automation. Just tell them to pull a neutral wire to all ur light switches as well. Standard practice is to only have live wires. So when they do ur reno, just tell them you want also a neutral wire at each light switch point too.
PM me please, TIA!
just use an intelligent power plug
TP-link sells them. Other companies too.
http://www.lazada.sg/tp-link-hs100-w...-67980204.html
The ceiling light is a little tricky. Tp-link also sells light switches but you need an electrician to pull a neutral wire to it.
Alternately, you could play with intelligent bulbs that are managed via your phone. But for them to work, your wall switch must always be in the on position.
The tp link intelligent power plug (TP-Link HS100 Wi-Fi Smart Plug) is it each electronic device plug need to buy 1 plug $48.90? Is it my fan plug into 1 tp link plug, my TV plug into 1 tp link plug?
If my fan and TV is nearby, can I plug the fan and TV into a 3 way adaptor, then plug the 3 way adaptor into 1 tp link plug? (so buy 1 tp link plug enough)
Ceiling light "wall switch must always be in the on position", if the intelligent bulb light is switch off via phone app, is it still using electricity?
Ceiling light seems tricky maybe skip first.
Thanks.
