You have the frequency information on Malaysia channel?
Try 682MHz.
Could I check with the gurus here, if I am using a dvb-t2 external set up box with active antenna on my current TV, how do you enable dual sound setting in a Korean drama for instance? Can't use that function at all, when I am on digital channel compared to analog channel
Sent from OnePlus ONEPLUS A3000 using GAGT
Not sure if tis had been asked b4, if indeed had been asked b4 pls pardon me.....
With analogue signal ending on 31 Dec 2018, does that mean the scv/tv point tat is provided in all hdb units, which links to a master antenna on top of every block of hdb flats is no longer needed?
Am asking tis becus bought resale and now renovation, so was wondering need to move the existing scv/tv point to my tv console side or nt since i am assuming its reduntant for digital tv
Thanks in advance for all answers!
Thanks bro. Will try again the next time with a Korean dramaUse the "Audio" button on remote control to select the right audio stream.
had bought a K2 mini dvbt2 setup box.
Where can i get the latest firmware for above set ?
Regards
List your current version.
Hi It showing as
Model: GHANA
SW Version: 20150728V4.0
Is there any cons buying a tv that has DVB T2 tuner built in already?
If the internal DVB T2 tuner is lousy signal can I still attach a external DVB T2 tuner box to it (buy a better external digital tv box and not use the internal built in digital tv tuner)?
The only con I think is if next the DVB T2 tuner faulty then the whole tv cannot use must change whole TV $200.
ordered this from alibaba for around S$8
looks like the same one from Qoo10 but half the price including delivery
hope it works
http://www.straitstimes.com/tech/more-time-to-make-switch-to-digital-tvThe Straits Time said:Analogue broadcasts to end by Jan 1, 2019; 75,000 low-income households yet to switch
Singaporeans still depending on analogue signals to watch free-to-air television will now have an extra year - till Jan 1, 2019 - to switch over to digital.
Only about half of the over 139,000 low-income households here have made the switch to digital broadcasting, despite the roll-out of a help scheme three years ago. All in, with just two months to go before the original termination date for analogue broadcasts, a quarter of households have not switched.
Although three-quarters of some 1.2 million Singapore households are already receiving Mediacorp's digital TV signals over the air or through their pay TV set-top boxes, there are still some 75,000 low-income households that have yet to make the switch to digital broadcasting, said Dr Yaacob.
These are people living in one-or two-room rental flats, or those on ComCare or self-help groups' help schemes. They have a monthly income of $1,900 and below, or an annual property value of $13,000 or lower.
Under the Infocomm Media Development Authority's (IMDA) help scheme rolled out in 2014, the needy households are entitled to free equipment.
IMDA has sent out notification letters to over 139,000 households but only about half have claimed and installed their free set-top boxes and indoor antennae, said Dr Yaacob in his written parliamentary reply. IMDA will be intensifying outreach efforts by knocking on doors and working with the grassroots, but this is "not sufficient", he added.
Therefore, the Government decided to extend the deadline. It will also beef up assistance for needy households and will announce the new measures early next year.
The deadline extension will also better align Singapore's analogue switch-off date with that of its neighbours Malaysia and Indonesia, expected to be around the beginning of 2019.
There are plans to use the freed-up TV frequency to provide more capacity for mobile broadband in Singapore. Having neighbours that have also switched off their TV frequencies will reduce interference problems for mobile broadband users. Harmonising the move will also facilitate mobile roaming.
Hello all
got an external DVB T2 from q10 and tonight suddenly it became got sound no picture. Tried switching it off and on again, the picture only lasted for like 2 mins then the screen became black again.
Anyone experienced this before? Thanks for sharing.
List the model of the STB and antenna used.
Very useful video.Happy new year to all!
It's the year of 2018, and this also means this is the last year of analogue TV in Singapore before it gets fully replaced by digital TV(unless the govt. extends the deadline again ).
Remember to switch to Digital TV before the end of 2018 if you're still viewing Mediacorp channels with the ANALOGUE word below the channel logo!
---DIGITAL TV---
Switch to Digital TV now!For DVB-T2 digital-ready TV:
For analogue-only TV:
Digital TV TVC
