dreamer_jul
- May 25, 2007
Which is better in terms of connectivity? Hotlink or Digi?
been using my TRON prepaid simcard for a few years and thinking of changing.
I will need long validity, data and local/overseas call, is OneXOX the preferred choice?
If possible, top up the card but don't buy the 2GB for 7 days plan.
Starter pack come with preloaded 300MB for 7 days; if not enough, can spend RM1/day on IDD and enjoy FREE 1GB high-speed Internet for the rest of the day.
OR you can get those one time 1 day plan via their mobile app; either RM1 for 300MB or RM3 for 1GB +1GB (1pm-7pm) depends on your usage.
Yes, ditto the RM1 IDD call for 1GB of data.
There's an alternative that I love to use (just plainly for convenience) if I am there >3 days: RM10 (7 Days, 1.5GB Quota).
In addition to that, enjoy 1GB everyday from 1pm-7pm and another 1GB from 12am-8am (only for Digi Best plans - this is available as long as your card is active - there's no need to subscribe to internet at all). In other words, your 1.5GB Quota will only be used between 8am-1pm, 7pm-12am.
However, if you're looking for value, the RM1 IDD call would be a better choice.
Top up before trip then consume the credits along the way?
hey can i ask which digi prepaid sim plan is this? i am going jb for 3 days and probably will just need data. gonna use the sim card as mifi.
please advise. thanks!
Hi, I try to top up the digi but the transaction got terminated.... any idea why?
is it commonly faced?
How did you do the reload?
No, not common.
I try to pay via Visa, tried using mastercard.
Previously I top up via those mobile shops buy their card.
Now digi app I can't use alr.
If you want to reload while in SG, can consider doing it here - https://www.e-pay.com.my/shop/category/1/mobile-reload - payment with credit card. It'll generate the 16-digit code for you to enter for your reload... can use the MyDigi app to do it as well.
Can use the following link to do the reload, if not wrong e-pay do accept foreign credit cards.
Why can't you use the MyDigi app anymore?
You can try to log in or register if you've not, from here - https://connect.telenordigital.com/id/signin - Mobile number has to be in full +60141234567.They keep prompting me "use a digi mobile to login"
When I am using it... And I see the playstore, a lot of problems about login... Haha
So atm, in Malaysia I can't determine my data...
And currently I am not using the digi best but the digi prepaid live... Maybe I gg to get a new sim card =x
When using the MyDigi app after that, just choose to log in with Connect - same User ID and password.
Sorry I admit I'm lazy to read through the entire thread.
I lost my good old Tron card and I'm thinking of getting another prepaid card. I go in monthly and my trips are usually between 1-3 days depending on where I'm going. What's a good data only card.
This seems good since it's just 1RM a day. So I just head to a counter and tell them I want the cheapest digi best card?
