Huawei Mate 10
vaxvms
CS0287
Should be =:p... Yet to try it out.
Initial explanation i found out is :
Portrait mode : Enable Portrait mode to automatically apply beautification effects to everyone in the frame.
Later i did find out it for the bokeh effect.
Thank for your info.
Actually I think the potrait mode is more for beauty effect to everyone in the frame, because I realized that wide apperture and normal mode both seems to have same bokeh effect �
deckcard
FYI, it is possible to debloat and disable Huawei system Apps to speed up the phone and free some memory
hoks
Hi all hv another whatsapp question. How come I cannot see downloaded whatsapp photo n vids using gallery app? I need to use es explorer and go to the whatsapp sub folders to find them.
deckcard
From your gallery, click on alblums tab
hoks
I only hv camera, camera video, screen shot, magazine unlock and recently deleted. No more d...
knave
For those who wants to change their system font, can now do so via the app Themes Manager for Huawei Emui.
Can even upload your own true type font files from pc to run.
deckcard
the icosn are too huge
is there a way to make them smaller in options?
Did you try changing view mode in display? It will be system wide size change tho. So I never bother with it and use Nova launcher that can customize pretty much everything and not affecting other stuff
deckcard
Checked liao... Dun hv le.
Hmm.. weird, can try clear data and cache for gallery and see if it rebuilt the thumbnails. Also can try using the stock file manager to access the pictures to see if it rebuilt the thumbnails in gallery. Open the pictures and use gallery when ask what app you want to use to open those instead of using other apps
hoks
OK went gallery to clear data n cache no effect. Then went to files and navigate to WhatsApp folder and try open a pic.
No option to use gallery leh.
deckcard
View and edit should be the stock gallery. Also take a screenshot of what is in ur album tab
