Xiaomi Redmi Note 4X
Hailgod
It will probably come with MIUI 8 pre-installed, but MIUI 9 is now available to Redmi Note 4X already.
probably miui9. dont think they keep stocks for so long.
i recommend moving to beta global rom before setting up the phone though. notifications are much better
Sent from Xiaomi REDMI NOTE 4 using GAGT
magixz
My note 4x cannot connect to overseas network. Shows forbidden, isit phone spoilt? Works ok locally.
Sent from Xiaomi REDMI NOTE 4X using GAGT
Anyone?
windwaver
I read from xda that some folks buy the sony sensor to replace the omnivision sensor at USD$10.
I am toying the idea to get a cheap export set to play with the custom roms, but then the camera are rather impt to me.
If can match or close to s7 edge camera quality, can liao. :s13:
I read that using goggle cam with HDR can improve the shots but it'll take longer to process.
windwaver
I just tried with version 5.1.018 and it seems to improve shots. Even with HDR+ enabled there doesn't seem to be any lag.
ZrE0_Cha0s
hmm... interesting. I though that on HDR mode always required a certain few seconds to process in order for us to proceed to the next ?
Hailgod
it does take awhile to process the images itself. but those images are captured very quickly.
The main draw of gcam is google's "ZERO SHUTTER LAG". taking a hdr photo doesnt take longer than a standard photo. The processing can take awhile though
magixz
where? I only saw https://m.qoo10.sg/su/419836602/Q110184285
Hailgod
ngbc
Export set $168 but No warranty !
https://www.qoo10.sg/g/545324581
Chevalier
Get this or the j7 pro?
Redmi willl be the 4gb/64gb variant
Sent from Samsung SM-G950F using GAGT
ZrE0_Cha0s
