[Recommend] Good Mechanical Keyboard
Buckbrick
I looked for certain options today. It seems that there are not many bluetooth mechnical keyboard so I will have to either pay a very high price or settle for the wired option.
What is a "good value for money" options for the wired/wireless keyboard?
what are people's experience with Magicforce or Poker? It seems they are better options than Vortex because I am not using my kb for gaming (only use it for a lot of typing - 2000 words/day).
Then get a basic wired Filco? Unless you want to move the kb around, just save and get a wired one. Remember seeing it going for 189. I'm using a Ducky one in office. Replaced with pbt caps. In retrospect, I would have gone for a Filco. But for office use, I just went for the cheapest non-mainstream Cherry MX board.
FatalityV
Would you mind sharing how? The arrow keys is the main reason why I still wonder if I should use the 60% kb.
Which poker kb you used btw? And what kb you are using now?
Im using a GH60 Satan now.
I used the poker 2.
On the poker2, fn is the default activation key for the second layer to use wasd as your arrows, and 1~12 as your function
jayz89
I am using anne pro too.
Saved so much space on my desk on a 60% board.
My filco majestouch 2 collecting dust till now..
FatalityV
sometimes play games bobian use full sized board, for my desktop
but for work, definetly will chose to use a 60%board instead.
EquinOoX
any mx brown keyboard, single color backing is enough? prefer white lighting and with numpad
Lucky_Farmer
Can consider Anne Pro 60% keyboard if you don't mind.
Can be noisy : Can choose blue, brown or red switches (Gateron or Cherry)
Wireless: It has bluetooth 4.0 (it comes with a bluetooth dongle as well if you don't have any)
No lighting: There is RGB for the Anne pro, but you can disable the backlight. This will increase the battery life to 2 - 4 weeks
Less than SGD 200: Got mine from taobao at a total of ~82 SGD.
Hope this helps
So, after all the researches other people's recommendations, I am back to your first suggestion. Please can you share the taobao link which you ordered the Anne Pro for 82 SGD. My Mandarin is pretty limited - hopefully it will be enough for Taobao.
lexmarq
Sent you a PM:s12:
acertey
was looking for a keyboard as well, the magicforce 108 keys looks pretty amazing. Was thinking where do you guys get nice keycaps? Preferably i was looking that those with front print instead of top.
Shahmatt
Can recommend a full size mechanical keyboard with volume buttons or media keys?
No need RGB or any special features. Will not use for games either. Preferably compact width.
Edit: Preferably also using PS/2 port.
Buckbrick
Get a programmable kb and program the media keys.
Shahmatt
If you program a key then to activate the program do you need to click on Fn or something like that? Or can be direct press?
E.g - If I program F9 to 'Mute'. To enable 'Mute' do I press Fn-F9 or just F9 is possible?
royfrosty
Anybody here owns a Topre keyboards and mod the sliders to cherry stems?
How does it feel when you swap to cherry mx stems?
Buckbrick
I’m using Ducky. Just switch to layer 2, program the media functions to any F keys, then leave it on layer 2. Then simply press the F keys.
jayz89
Hmmm my anne pro brown switch the backspace keep tio stuck and doesnt depress upwards now. Any solution?
royfrosty
Check the stabilisers? Pull out and see if the stabilizers are still working.
There are 2 types, not sure yours are what kind of stabilizers.
- Costar stabilizers has 2 different clips that holds the space bar. Usually this type if your key doesn't springs back up is could be either one side of it came off or the stem that is holding the spacebar could have dropped out.
- Cherry stabilizers this stabilizers are straight forward, if it stuck means either the stabilizer has something inside, or it could be your stabilizer got some sticky substance like sugar water stuck inside or it just spoil.
Psycovirus
Any thoughts on this keyboard?
Massdrop x OLKB Planck Mechanical Keyboard Kit
I would like a compact keyboard for work. I mainly type a lot of emails/reports. Don't really need numpad.
Would you recommend this?
What keys should I get with this?
office environment so I would prefer something quiet yet tactile. MX Brown/Clear or Matias Quiet Clicks?
Thank you in advance for your input.
ragnarok95
Senior Moderator
Senior Moderator
You can try Vortex Core, Vortex Poker 3.
royfrosty
For work I prefer a full size. But it all depends on your work. For me I have to use the numpad.
If you don't mind investing I would recommend Topre switches instead. If you are long hours of typing, Topre do helps as it doesn't make your wrist or fingers too fatigue.
Try it out.
Else you might wanna get something like black switch mx keys. Hard to find in sg, but if you like it, order from Amazon.
pedokuma
My ducky one, the led failing. Some button no lights, and when I off all the lighting, some button have light.
Feel like changing to tkl keyboard too..
