Dr.KongHee
- Jul 11, 2012
how is mate 10?
how is mate 10?
Seems like starhub has volte enabled for mate 10 pro! I can see it at locked screen with volte logo![]()
I didn't experience 1.Some issues with the mate 10 pro that i've noticed while deciding if i should purchase this.
1. WiFi stops functioning properly after awhile. Connected but doesn't pull data. Slow wifi speeds
2. Apps get killed off/stops functioning when you exit it. I.e. apps stop syncing/downloading
3. Widgets/background apps stop working after phone goes into deep sleep (not used awhile)
4. Notification problems. Apps don't report notification
I can't tell if these are common problems or one-off issues. Could the users here share their experience if these are indeed/still problems with the later softwares?
But 2 and 3 , I totally agreed with you! This problem is annoying. I guess it's their way of saving battery.
No. 4 should be due to no. 3 I think.
Not sure if it's really me, but my Mate 10 non Pro seems to have something similar to this.
WiFi was "connected" this morning but I couldn't surf the net, only opened up old cache version of the webs that I have.
Play Store also keep "searching for update" and my installed tab is empty.
Disabled and re-enabled the WiFi and then everything worked smoothly again and Play Store loads up fine.
Seems like the WiFi will cock up after extended rest or something? There's the up/down logo but can't load anything.
no issue for no.1
2 and 3 i guess is individual app compatibility issue.
mate 10 cannot use amazon app, while Sony can (sorry I only own sony so don't know other phones)
no. 4 maybe is Android 8 issue or setting?
More likely is Huawei own implementation...Could this be due to OS behavior?
Same issues on my Mate 10 pro...
Issues 2 & 3, I've read that changing the settings, to give app priority + whitelisting + disabling battery optimisation for the app doesn't work too. Apparently emui is aggressively killing background apps. Is it to the extent where exiting a browser while downloading stops the downloading process as well? Someone in this thread mentioned Dropbox would stop downloading/syncing when he left the app. Would like some confirmation on this as it would imply broken multitasking. =\
Is that a hardware fault or software? Wondering if go service center worth it or not.
