Oneplus 5T
KeYoKe
IOS notification is really a mess. It wont group similar app notification together lol. For me, it doesn't really matter whether dots or numbers. I just need to know if there are new notifications will do
technolust
Oreo update came Liao? I just checked today but no have . Anyway sell off today Liao :(
Just updated to official Oreo, VPN to get OTA, performed a cache wipe after. My God, the phone feels super fast and responsive now. Much better than nougat! Thanks to bro keyoke for the heads up!
Sent from OnePlus 5T Lava Red using GAGT
onlinehero
The oneplus tpu case.
Clasy tpu case from mobile hardware
I bought some cases from revelion..havent use yet but pray it will fit the tgsp
bought the nillkin TGSP to go with my rugged armor but messed up the application :(:(
was thinking if i should get the orzly (cos its 2 pcs) but that will mean i need a newer case :o
another option will be to get the spigen's TGSP but it doesn't ship to singapore atm :(
though..despite me messing up the application of the nillkin one, overall it looks good, texture is good, the edges paste well, and lots of room for thick lip cases. just poor clumsy me :(
think i'll order another Nillkin one :s22:
jtec14
Was on 5.0.2, and noted new OTA 5.0.3 (VPN to canada)
Change log same as 5.0.2 except for Fixed system stability issues
jtec14
I used orzly with ringke fusion.
Skyy
how did u mess it up? got dirt underneath or u didn't paste it straight?
kashix
Thanks... So before update to Oreo, clear cache first?
Sent from Nokia 8210 using GAGT
Major system upgrade if you coming from nougat to Oreo, can consider clearing cache, after you update then clear
onlinehero
something even clumsier than that. i was about to paste, then noticed got dust, so reached out for cloth, wiped, then immediately pasted swee swee aligning all...
...only to realize i reached out for the wet wipes rather than the dry cloth. :s22:
so the adhesive side sticked to the wet surface then it just went downhill from there :( tried to clean the adhesive side which made the whole thing worse :(
P R N D
I straight updated to Nougat to Oreo oxygenOS 5.0.3
Then boot to recovery, see the selection: Wipe data and wipe cache.
Cannot find wipe cache only.
It's that mean you reinstall all your APPs and setting after update to 5.0.3?
Sent from Oneplus Galaxy S8_edge_plus using GAGT
