Additional SIM card for same number
hokeylim
Hi
I remember it was possible to get a 2nd SIM card previously for the same phone number.
May I know if its still possible to do so, even at a fee? I haven't renewed contract or signed on line since donkey's ages ago so I have lost touch.
Thanks in advance.
ZrE0_Cha0s
U have to check with the telecom on this matter as not many people will knows their current policy allows it or not.
lohsenglte
Do you mean MultiSIM, or replacing your SIM card with a new one?
If you’re referring to replacement of SIM card, it should be possible, however it’s unclear if the carrier will do replacement for free (considered lost Sim) or chargeable @ $37.45.
ZrE0_Cha0s
Well I believe he means multi SIM.
lohsenglte
Yes. I meant multi SIM. Thank you.
If you’re on singtel, MultiSIM is discontinued already. You have to subscribe to MobileShare, but with different number and your plan may not be applicable (you said it’s old plan), it’s a game.
If you’re on StarHub, MultiSIM is available for Postpaid Mobile plans, not for mobile broadband plans. $48.15 upfront, $10.70/mth thereafter.
If you’re on M1, you can apply MultiSIM for Postpaid Mobile & Mobile Broadband plans. Same cost as StarHub.
hokeylim
Thanks very much for the info, bro. Very helpful.
koreanlover
Thanks for the info.
harky
yes, it has a charge. call ur telec to check
