[MERGED] Third virtual mobile telco: Zero1
Spirax
Likely it is M1 vs Singtel price wars thru virtual telecom, Starhub may had given up on consumers market
Razor
quite interested in this
free voice roaming via its Zero1 app, slated to be launched in June. With the app, subscribers will be able to call and receive calls from any Singapore mobile or landline number for free while roaming overseas
PongRareRare
https://zero1.sg/faq/
#11. Are there charges to re-contract with Zero1?
We will always welcome you to use Zero1. However, do note that you may not be able to retain your choice number. In addition, there will be a one-time joining fee of $10.70 and $21.40 for the new SIM card.
This is misleading. Don’t anyhow quote without showing everything. What u quoted is for those who joined and left and want to join back.
For the port in,
3. Can I port my existing number to Zero1?
Yes, you may port over your existing postpaid number to Zero1.
You will need to fulfill the following requirements before you can request for transfer of your mobile number to Zero1’s network:
Your number is a post-paid number with your existing telco.
Your number is registered under your NRIC/ID with your existing telco.
Your number is not inactive/suspended with your existing telco.
There is no outstanding balance with your existing telco.
Your number is no longer under contract with your existing telco.
If it’s a ‘yes’ to all of the above, please proceed to pre-register your interest at https://zero1.sg/register-interest/
Alternatively, you can sign up for a new number with us first and request for number porting at a later date. We will be back with more updates closer to our service launch.
virus1988
I am on 2GB plan, sometimes 1 month use 300MB only
only exceeded once when my home fibre modem was down, and I used my mobile as hotspot
Mine is still under 12gb free data since 8 years. Damm shiok. Not going to re-contact to the new free 2gb data or whatever they deem to be "special". To me it's like they are offering me a downgraded version lol.
virus1988
I used to be on 2GB and was very mindful of my data usage to prevent overshot usage.
Now I switched to the Singtel 5GB SIM Only plan, not so mindful of usage because I normally won't use much unless my home wifi is down. :o
masashi
For the port in,
I hope the throttle would be 4G to 3.5G speeds, not 56k.
Great I can port over. As long they don't throttle too much then I'll be content since it's unlimited data :o
Sent from LENOVO P2 using GAGT
Mancunian2
12GB is on 3G only right?
are they still talkng about phasing out?
Naoyuki
Want to move away from M1 because the reception underground is super bad but I want the data roaming ..
TheZombie
For the port in,
I take it you are representing Zero1 in your official capacity.
I quoted in full what was stated as #11 on your faq: I did not “anyhow quote without showing everything” whatever that means...
And if a person who takes up a new number with Zero1, then leaves, and comes back can (or not) retain his number. Or under what circumstances will retaining our number may not be possible.
Don’t accuse us of being misleading when your faq could be worded clearer and without doubt.
blankies
What you quote is indeed misleading. Wrong liao dont be shy to admit la
Admit wrong will lose money issit or lose pride? :s13:
