[Official] Chromebook SG
dredd
ghgan1
Yes, Chromebook support flash. Having said that, mconline flash implementation might be a bit buggy when using chrome. Based on my kids experience when using mconline and other elearning sites that uses flash, if they encounter flash not working or buggy, I've tried the following potential solutions for flash compatibilities:
Site settings > Flash > Allow.
Try deleting the browser’s cache and cookies.
Try using the Google Chrome in the incognito mode. If that works, then temporarily disable your extensions to identify which one is causing the problem. To do this go to chrome://extensions and uncheck Enabled for each extension one by one.
Reset your Chrome settings to default.
Last but not least, if all else failed, switch back to windows.
Happy CNY everyone. I am interested to get a Chromebook for my primary school kids. Anyone know if it will work with MOE eLearning websites like MCOnline, Xuele and eZhishi etc which I believe still runs on Flash.
Thank you.
grenovic
Thank you for sharing your experience. Now I need to rethink if it is worth the trouble.
ghgan1
So far it is still fine, quite rare to use Windows for mconline as most 3rd party elearning platform the school are using are going to html5.
My recommendation is to get a budget chromebook with touch screen that is 13" - 11", cost should be around USD 200-250.
bingong
Thinking of getting a Chromebook, the Chromebook 15. But nowadays I worried that the laptop comes dead on arrival. Have you all had such experiences? Is there any way to mitigate the risk?
ghgan1
Buy from amazon, if dead on arrival can return back to amazon and they will refund you the money and shipping back cost.
hawthorne
Bought 3 Chromebooks from Amazon and so far it has been great. One of it has a small scratch on the side though, but after a while, I dun notice it anymore
Pandule
hi all. I have a Acer C720, used since 2013. now it's getting a bit cranky + no more software update. Any place where i can sell this to, and get a small token sum?
netsit
hi im thinking of getting a chromebook. I work in a full gsuite company so thinking of using a chromebook at home so i dont have to lug my work laptop home.
Can someone recommend me something?
Budget: $500
Work: Gsuite, Gdrive
Entertainment: Chrome internet browsing, youtube, some drama watching on streaming websites.
thanksss
wtfh4x
Will there be chromebooks on sale at Comex? i just want to get something lightweight for travelling
Why not get the new HP Stream with Celeron N4000? Better CPU than the Acer, proper Windows and also $399.
generalwu
Don't bother, you're better off buying on the internet.
So far only ASUS has them on their brochure but it's a Chromebox.
PsyClick
Wife's requirement is for internet surfing, Google spreadsheet drive etc. Maybe light YouTube.
I suggested getting a minimalistic chrome book cheapest but no idea what to look for. Any suggestions appreciated.
Other requirements
13 inch screen
Light weight if possible
Thanks
Sent from Google PIXEL using GAGT
generalwu
Other requirements
13 inch screen
Thanks
Amazon Link here: here
Cheapest I can find on Amazon. :)
momoloves
Has anyone tried the ASUS Chromebook Flip C302CA or Acer Chromebook Spin 11 CP311-1HN-C8MV?
generalwu
Read the reviews for C302CA and it's good, worth to buy if you're into Chromebooks. However for Spin 11 I'm not sure, it's just another normal Chromebook with android support.
C302CA will be faster then Spin 11 by alot.
Hope this helps. :)
Freshy
any idea how to get chromebook to auto connect to the free wireless@sg ?
squarepipe
If you know how to run your own VPN server at home, set one up with port 53. If you connect to wireless@sg or any other public WiFI with VPN on port 53, you get to skip the captive portal login :)
evelynleebali
Hope this helps. :)
this helps a lot! Thank you! I am looking into more reviews before enjoying 1.
Freshy
thanks for the reply.
but i noob. :o
got to read up on what u have shared. thanks again!
