xsoldix
- Apr 17, 2010
Anyone tried this with homebridge?
Thinking to get and do it for TC2 light switches.
Thanks for prompt reply. I've already created a TV template for TC2 but the problem is how to get the app learned the on/off command unless I have a separate remote controller.
Do you need the Neutral wire for the TC2?
The remote you can buy from TB for about 10sgd.Keep us updated if it works from what I understand the TV template only learn IR signal, RF won't work.Thanks for prompt reply. I've already created a TV template for TC2 but the problem is how to get the app learned the on/off command unless I have a separate remote controller.
I am not successful to add the RF wall switch to IHC app.Hi all, when in broadlink app learning the tv template, when a button is in learning mode, your rm pro will wait for any signal to be fired to rm pro to learn, regardless it is rf or ir.
Probably due to many type of devices out there, not all tv remote is IR... Not all light is RF only.. Therefore no such restrictions.
So just click on a button to learn ... Fire the to be learn signal.. Rm pro will learn... Regardless wat template u using and for both ir and rf signals.
Hope this helps.
I chose Yoogee because I am able to wire 2 way control switch not sure if the Broadlink is able to do the same.There is 2 connection for wire A and wire B which were used to wire 2 way switch. One of switch output is connected to the lights, the other is connected to Live wire, I just pair the function to learn the switch which control the lights. And it become a 2 way switch to control the same light from 2 switch
Hey there, able to guide me on the wiring?
I'm using livolo 2 way and it comes with a and b connection as well. But my current 2 way only has 3 wires.
From the instructions it seems like we need 4 wires instead of 2.. 1 live, 1 switch, and 2 wires for a and b.
Yep.. that's the one I'm having issues with. I only have 3 wires and this one requires 4.
1 seller on amazon told me to connect b only and leave a empty. Have not tried yet.
U mentioned u using yoogee rf wall switch... How u add a tv template to ihc app? U need a physical remote to pair to ur yoogee switch and den let ihc tv template learn the rf signal of the physical remote. U done this part already ?
Spot on! We exactly same devices... Just dat mine is rm pro3...
Is your Livolo 2 way working?Note.. the EU version is smaller.. for those who go for it..
How to control RF device with Alexa? Using TV Template?
I have 6 dooya curtains using RF remote but I can't learn using IHC app to use the Alexa Broadlink skill.
How did you do it? Im using rm Pro +
The TV template is only for IR and some RF signal. For the RF switches it will not work probably need to buy a remote to learn then teach,because when I press on or off switch the teaching not successful. Tried to add custom device and sweep frequency also not successful. Only the e control app works by adding RF wall switch, then choose Manufacturer as Yoogee will pair successfully
Hi both,
im using rm pro3 with IHC app, to communicate to alexa.
Vixx, u can use the on/off switch of ur curtain to IHC tv template 'on' button.
after u done, first test the IHC newly created button to see if it works, before trying on Alexa. (please kindly refer to video below)
S750WP, yes, u need a physical remote to pair to ur yoogee switch, so that u can create a IHC tv template and learn the same signal on the physical remote, this will allow it to 'talk' to alexa.
otherwise another route is to use RM plugin on android device, to talk to Alexa, as for this route im not too sure as i nvr did before but i think some others are using it.
https://youtu.be/Lg4HQhN5KXo
