elmariachi
- May 30, 2005
Personally have owned a G-sync and I can tell you makes a hell of a lot of difference only if you play fast paced FPS games. You won't notice any difference other than just generally smooth graphics if you have G-sync but do not play fast paced games.
It helps exponentially more if you're running higher resolutions. I'm running ultra wide 3440x1440 and G-sync working and keeping things smooth is far more noticeable than my previous 2560x1440.
One thing you have to remember is that there is an optimal way to setup G-sync. Many still don't know how to set it up with the right settings and when with the right hardware, the wrong combination of settings can ruin your experience.
For one, I'll recommend G-sync if you have a competent NVIDIA card play really fast motion games. If you don't, you probably won't realise the need to unless e-penis.
