Just got popsical... Link to denon amp with 5.1 system... No Bass at all... So sad... Karaoke is really different...
Currently using android box with karaoke app, everything works perfectly except that mic no where to connect so can't sing.. android box mic in is not meant for singing, only for Skype, etc..
My android box is connected to my Yamaha ysp 2700 sound bar via hdmi, it does not have any mic in...
Any solution to connect a mic in this situation? I know I need some sort of a a mixer but not sure which type to buy...
Im having the same setup as you.
Android Box, YSP2700 soundbar and LG smart Tv, hdmi to RCA cables
My solution is to use UHF wireless mics with echo control on the mixer and RCA in and out ports.
The line out goes to RCA in (AUX 1) of YSP2700
As for the android box, i make use of the HDMI to RCA cables. The yellow cable goes to the tv, the Red and White goes to the the line in of the mixer.
The good thing is everything works out well. The bad thing is android box use analog sound.
what program or equipment, you actually use for singing then?
Hi billiejoe, How is the sound and graphics quality for Popsical? Does how fast is the streaming? Do you encounter any problems with the streaming through? E.g. mid song hang etc.I got the popsical with the soundbar and 2 wireless mics for $399. Good for new bto or for a room. Can choose to pay $3.99 for 24 hrs pass or $9.99 per month. Have all the latest english songs with original mtv. Upon buying, got 1 month free trial upon signing up for the popsical account. Good product.
any update?
i'm still looking for a home karaoke setup,
i got the speakers, the mics but no systems nor the apps..
please help
I'm using youtube as my search engine. Well its free. I just search for the song name without vocal or karaoke version. Most of the time youtube will have few version of it. Its easy and hassle free. Just choose the best version that suit you. As for equipment, i go for minimalist look. Sound bar with wireless mic and echo mixer. Not the best setup for karaoke system but i dont do karaoke much. My setup is more for movies and music. Its just a minor add on for me to do karaoke party at home.
actually youtube is the best but not many songs are without vocal..
can't complain much as it's free after all..
