Xiaomi Mi Max 3 - Come in!
i1magic
Dear all,
I am still using Mi Max 1 till now.
After watching the review of Redmi Note 5, I am pretty hopeful for the up and coming Mi Max 3.
So started this thread.
i1magic
No leaks for Max 3 as of now, but previously it was rumored that it may come with a 6.9" 18:9 display.
Actually, screen size 6.44" is ok liao. Not sure can tahan 7". LOL!!
As long as the spec is the same as the Redmi Note 5 and with the same camera, then good enough liao.
amazingone
An 6.99" 18:9 ratio display is similar to a 6.5" 16:9 ratio display.
The 6.99" 18:9 is just a taller screen of 6.5" 16:9.
carboy00
Announcement should be soon! Mi Max 2 was announced in May last year iirc.
Sent from LG G3 using GAGT
winningeleven
I compared my mi max 1 to Samsung Note 8 before. Mi Max is still much bigger than the 18:9 6.3 note 8.
Make it a 18:9 7 inch Mi Max 3 and my guess is probably get the same length as current Mi Max 2?
touchme
width, you meant?
Audiology93
Hope it looks as good as this
Snapdragon 635CPUOcta-core
MEMORYCard slotmicroSD, up to 256 GB (uses SIM 2 slot)
Internal128 GB, 4 GB RAM or 64 GB, 3 GB RAM
Camera PrimaryDual 12 MP (f/2.0, 1/2.9", 1.25 µm), phase detection autofocus, dual-LED dual-tone flashFeaturesGeo-tagging, touch focus, face detection, HDR, panorama
Video2160p@30fps, 720p@120fps
Secondary5 MP, f/2.0
https://www.gsmarena.com/xiaomi_mi_max_3-8963.php
Sent from Xiaomi MI MIX 2 using GAGT
kovovo
Issit still worth it to buy max 2 now?
Thinkin of gettin one later....
i1magic
Screen wise, I think 6.44 inch is fine. If it is 6.99" and width is still the same, then should be fine.
