Nintendo Switch thread - Part 2
JAson1980
The switch still dying from using 3rd party docks?
I have 2 sia, now afraid to use.
Ridiculous
i bought from shopee, cheapest i found was 80 bucks. is EU version, after some discount became 70 for me.
Hi, do you remember which shop did you purchase it from? Was searching for it on shopee as well and could only find $84 being the cheapest one.
jim123
Hi all,
Newbie here. Can I check which third party usb-a to usb-c cable is recommended for charging switch from a third party charger?
Thanks in advance..
MoosePlus
for me, i use my 6 port choetech charger with either the choetech cable or the default charging cable for my phone, no issues at all after 4 months. however, with the recent fiasco over the 5.0 update and third-party accessories, i'm not updating my switch for now...
jim123
Hi MoosePlus,
Thanks for the reply. Will take note on thee 5.0 update. :s22:
VodkaPear
I am using anker 5 port charger (1usbc, 4usb) to charge my mbp 13".
When there is a need to charge my switch, i jus unplug the mbp cable n plug into my switch.
So far no issue with 5.0 update.
Charles_Chi4
Anybody bought game in play-asia and it's different from picture? Seems like they do the same trick as some local shops. Put ESRB logo for mario rabbids in their webpage and send the PEGI item.
mohaha
did you ask them? most pple didn't care about the version as long can play and cheaper price since switch game is region free. so is normal for game sellers online to didn't care that much. you better off buying from amazon usa if you want an ersb verion.
Elysium87
anyone know where else to get mario kart and splatoon 2 at a cheaper rate for physical copy?
so far i saw is shopee selling at 68 for mario and splatoon 2 for 65
mohaha
Those are already cheaper then digital version on nintendo eshop. U can use coupon to make it cheaper or credit card promo to make it cheaper. Retail hardly unless they are 2nd hand.
Desmond_
High Honorary Member
i believe that is the cheapest already :o
