100mbps = MB or Mb? Your PC is on GbE or FE? Your NAS is on GbE?
If you are getting 100MB/s, you are already achieving your top throughput from your PC.
That's why i say you won't need 2 ports. You don't even know what you need to do to make use of the 2ports.
I don't use quick connect. I use DDNS(router), port forward(router) and sftp (nas) to do transfers externally
Hi Bro,
below are the screenshot from home PC.
Same transfer but speed inconsistent, using Synology Assistant login and map NAS to PC.
Same file, just rename the folder.
Using Synology Assistant login thru Quick connect web method.
The speed super slow...
Out of home I can't Map the drive right?
If using quick connect method, upload/download super slow.
Anyways to make the transfer speed faster when accessing out of home?
