amazingone
- Jan 14, 2015
Don't think so far leh haha, enjoy the Redmi Note 5 for now.What is to be expected for redmi note 6?
Finally managed to get 4k recording with stabilization, the main purpose of buying this phone...
If you want to get this, after you unlock phone, download this file https://drive.google.com/file/d/10vGz1Fb7l9YIIKz3Alcrano4vUxa6yua/view?usp=sharing
0) copy the magisk.zip into phone
1) reboot to fastboot (vol down + power)
2) after you unzip, press shift right click mouse, open command window here
3) copy and paste the following into command window
fastboot flash recovery recovery.img
fastboot boot recovery.img
4) In twrp recovery, reboot into recovery again. Somehow after flashing if you dont manually try to boot to twrp recovery, the default xiaomi recovery is booted
5) flash magisk.zip
6) reboot phone, go play store search for es file explorer or any other root explorer
7) Go to /system/etc/device_features/whyred.xml
8) Find the line that says "support_camera_4k_quality"
9) Change the >false< to >true<
Now you can open miui camera app
Bro, you use same phone number for 2nd account?
Wah power siau still go and hack/mod the system to support over it's max support
took some time to flash the TWRP. the MI recovery 3.0 keep replacing the TWRP...
Actually the Snapdragon 636 is capable of 4K UltraHD capture @ 30fps. Just that some phone makers decide to disable it.
My phone is encrypted gosh. Not sure how to remove. Have already remove data in twrp and reflash rom but still the sameyeah so weird.
Anyway i will try flashing global rom. The problem with china rom is that stabilization doesnt work on 4k. But based on youtube videos, it does work for indian roms. So maybe global rom might solve this issue
every phone after kitkat is encryptedMy phone is encrypted gosh. Not sure how to remove. Have already remove data in twrp and reflash rom but still the same
Sent from Xiaomi REDMI NOTE 5 using GAGT
On the Oreo global room, after removing unnecessary apps, unused "system app" with root app delete, setting apps to be closed on exit in battery saver, and greenifying non essential system app, the rom uses 2GB ram after reboot... About 700MB more than lineage. apps like security, cleaner, and don't know what apps still using ram
xiaomi just had a conference for the launch of redmi note 5 n mi mix 2s at thailand today , official release of global rom incoming soon ?![]()
is there a greenifying function? my greenify cant work with magisk installed.. i saw like RR rom prefers magisk, not SUPERSU
U mean using geenify app?not sure of auto but manually greenifying works.
unused ram is wasted ram. have u actually encountered issues with the phone due to lack of ram?On the Oreo global room, after removing unnecessary apps, unused "system app" with root app delete, setting apps to be closed on exit in battery saver, and greenifying non essential system app, the rom uses 2GB ram after reboot... About 700MB more than lineage. apps like security, cleaner, and don't know what apps still using ram
