Oneplus 5T
onlinehero
anybody noticed that since the gesture update, things such as insta stories are cut a bit at the sides
Sent from OnePlus ONEPLUS A5010 using GAGT
Eddied
Ya the stories are expanded to fit the screen, swiping up from the bottom also results in a lot of misclicks, I might switch back to the original bar soon
CrispyPeddler
Would you all suggest OP6 or Huawei P20 Pro? I'm looking to change my good ol' OP2. XD
depend on what u looking for.
in terms of cpu power / speed - op6
clean os (almost stock android) - op6
fast charging - same
battery capacity - p20pro
camera - p20pro
feature (usb c, ip rating, infrared) - p20pro
im in dilemma also...
Shadowz1984
camera - p20pro
If you can wait, export set of OP6 would be cheaper. But then again, huawei phone price drops quite fast. So few month down the price of export set 128gb OP6 should be close to p20 pro.
I think what you should compare probably would just be the camera and OS. CPU power you probably wouldn't see much of a difference in day to day usage. Those benchmarks serve no purpose.
sleepyjoy
camera - p20pro
Excuse my ignorance, but what's special about P20's USB C feature?
Ya, OP6 camera doesn't seem to be as great as hyped. Sucks =/
Audiology93
Faster transfer speed and USB 3.1 support display out.
Sent from HUAWEI MATE 10 using GAGT
sunht
Don't know if the slow motion video on oneplus 6 comes to 5t or not? Hope it's just software
Sent from OnePlus 5T using GAGT
onlinehero
5.1.2 OTA is up on VPN. (1.6GB)
- Added Double-tap to lock screen
Good stuff
apart from the double tap to lock, any other significant improvements? the double tap to lock function can get from updating the oxygen launcher
UVERtainment
Changelog:
System
- Updated Android security patch to 2018.5
- Fixed auto-rotation stability issue
Gallery
- Places: a map view of photos by location
- Added “Recently Deleted” collection
Wireless & Network
- Fixed Wi-Fi connecting issue
Launcher
- Double-tap to lock screen
Earphone
- Fixed microphone not functioning issue for AKG earphones
