Viewing Distance Discussion Thread
bargin
Pete, for 2.5m to 2.7m should I get at 50" or 55" to watch SD channels ? To watch BR, what is the distance to watch comfortably ?
petetherock
Moderator
Moderator
mysky26
Hi Pete. Sorry I do not quite understand. So for a distance about 2.5 meters, if only view 1080p videos and tv, what size should I get? I think 50 is sufficient. Is 55 too big?
bleonz
tbh 50 and 55" does not diff alot...and nowsaday, in mkt...hardly see 50" models.
tk
55" for 2.5m viewing distance is still comfortable.. no worries about it being too big..
zephyr11
quick qn, my wall to wall is about 3.8m, so viewing distance should be about 3.5m give or take, 55/65" ?
thanks!
petetherock
Moderator
Moderator
thanks!
65" - viewing 4K?
2m or even less is fine. At the same distance, 55" will be pretty small.
Toastyliving
I made a simple brochure for the viewing length of UHD/ 4K TV.
375076596630098
facebook.com/toastyliving/photos/a.374212826716475/375076596630098/?type=3&theater
alamak
Need some advise.
Viewing distance of 2.1m. Mainly watching fta channels, Netflix, YouTube and Google/iTunes movies. Thinking of getting a 55" Oled.
Will it feel like sitting in the front row seat and uncomfortable?
tjeeyang26
The other consideration is a comfortable field of vision.. which is around 30-40 degrees..
http://www.avbend.com/blog/how-to-calculate-tv-size-and-viewing-distance/
Need some advise.
The chart should be able to provide you the information you require
petetherock
Moderator
Moderator
Need some advise.
I use a 75" at 2.5m
