SBF - May 2018
3G SAINT
Hi...new here...looking at the dawson units but 3 room...anyone know if the 3 room has resale potential after MOP? or only 4 room? am looking to upgrade after 5 years. thank you in advance!
Toa payoh 3rm sure have potential and near mrt:)
Nw 4rm got 5.6 times but 3rm only 1.0 and many 2nd timer aim 3rm:D
Yishun 4rm also many 2nd timer but far from mrt but got lower seletar reservoir view:)
Yishun 4rm getting expensive compare last time:(
87nivlem
Anyone know how does Married Child Priority Scheme (MCPS) works for SBF?
As SBF consists of flats that are spread around the town, do i qualify for MCPS if only a few flats are within 4km from my parents’ flat?
Weeli85
Yes, work with all the new flat. Even your house and your parent house different town but within 4km, still acceptable.
cashec
87nivlem
Thanks!
What if for example i applied for Punggol, and my parent house is in a different town. Out of all the flats under SOB, only a few flats fall within 4km. Can i apply Punggol with the MCPS?
Weeli85
Thanks!
You can click the below link for calculate the distance
https://services2.hdb.gov.sg/webapp/BB292KM/BB292KM_ENQ
But remember once u use MCPS, your parent cannot move out from the flat for additional 5 more years
chows99
But under MCPS, can the parent move house but stay within the 4km radius?
kingboonz
Hi guys! After applying without any priority schemes, I realised I actually qualify for one of the priority schemes. Is there any way to edit my application?
vinno18
You should be able to amend your application by going to the page to apply for the bto and scroll to the bottom to amend. That's how I amended the address for the MCPS.
edyst37
Hi all, for SBF, how do u select the Fiancé/Fiancée Scheme? when reach the application preview, it still say Public scheme. Thanks
edyst37
No idea too. Mine also public ._.
Thanks, think it does not matter for now. Saw in the BTO thread. :"There is nothing special about fiance/fiancee applicants..All would be listed under public scheme..
It is not a scheme by itself, it's just a family nucleus.."
AlexPiero
So far from what i see...the best location is Dawson oasis.. is like 3mins walk to queenstown mrt...but not sure abt sound pollution
cre8ate
Hi all,
I was wondering if i can apply for May SBF even though i have been given an appointment date for Nov2017 SBF. My Q number is 2xx but currently only serving 102. There is only 17flats left for Chinese Quota so i think most likely there wont have any quota left.
If i go ahead and apply May SBF, will my Nov2017 SBF be automatically cancelled? Or can still go for the selection on appointment date if there is still flat left.
Also, does anyone know if both my fiance and I are overseas, is the "Authorisation Form" the only document that is required? Or the whole appointment letter and documents required.. Have to sign some forms but both of us are not in singapore during this period.
TIA!
(PS: Wanted to call HDB but tmr is public holiday)
Aries89
Hi all,
TIA!
Deadline for May SoBF is tonight 11:59pm, better apply now if you're interested. I believe as long as you have not chosen a unit yet, you can submit another application and your previous one will not be cancelled.
Have you rejected any chance to select a unit before? If no, then should be no problem rejecting your Nov sobf when it comes to your turn (assuming you still have a chance) and still can go ahead with the may sobf
