Nokia
lohsenglte
Is the 2nd logo from the left showing VoLTE?
VoLTE normally would be at the right side together with the signal bars deh. Not sure if it's Nokia or Android One, it's a Call logo with LTE beside it.
I do know MIUI shows VoLTE or HD (depending on MIUI version) to indicate VoLTE. My Redmi Note 4 MTK show "M1 4G HD" on some versions of MIUI 8.5, but MIUI 9 has been showing "M1 4G VoLTE". Never 4G+, simply because XM doesn't want to allow Interband CA.
tiger2013
Mine don't have network signal 📶 bar either way :(
You use themes?
I was fooling around launchers and the icons went missing because of the themes. The colours tak match, so it was camouflaged.
Revert everything then can see.
derrick__
Certainly. I wonder if they don't display or don't support.
Yes, that the confusing part. Not sure anyone on M1 network can try with their N7 plus since the phone is selling officially in their stores...
Sent from HMD Global NOKIA 8 SIROCCO using GAGT
kopi22
Don't think Nokia mentioned anything about X6 during the launch.
PC-User
Yeah loh. Thought they would. Sigh, when when when...?
7 Plus is too long ang heavy. If not I would have gone with the 660.
Ed.YEO
屏幕大半寸。。。處理器,電池一樣。。。續航時間會加長咩?​
