[Recommend] Transformers: Earth Wars
templton
Ya, that's why I had to skip other buildings and do the hq and storage too. 40 to 50 should take quite long,will stop at this hq for a while to max the other buildings
yea.. max those defenses... and get ur base layout nicely laid.. so it can protect ur resources :)
templton
hey guys....
get yourself a good alliance that will finish this week event.
end of event will give u a guaranteed 4* crystal.
whatheheck
Don't think can protect, all those hitting has 3* 700-800power :s13: what the avg max power of 3* anyway?
whatheheck
it can go beyond 1.5k.
maybe u gonna redo your base...
Wa so high. Mine at lvl 40 only 600+. Low hq12 close one eye also can breeze through :s13: the other time see one combiner hoot me, half def gone right away
spiffy123
you still have a long way to go my young padawan.
l40 is only scratching the surface of a bot being useful.
My 3* 52/5 Ultra Magnus is 1613 now.
spiffy123
Wa.... 52/5 means lvl 52.5? The power for 3* can reach so high...
52/5 denotes Bot level/Special Ability (SA) level.
So it means my UM is level 52, SA level 5. Both bot and SA level, and Power core level affects the overall Combat Power (CP) of a bot.
3 and 4* have a max level of 60. OP and UM will usually be the strongest at each star level.
The game also rates Hp over Damage, so in general Warriors that have higher Hp than Jets/Gunners/Specials etc, will have a higher CP.
whatheheck
So high?? ? My 4* deadend at 40 only 771, I'm researching it atm. I have 1 3* lvl 39 at 515 power only, another warrior 610 at lvl 37. Mine so lousy sian :s13:
spiffy123
Deadend is a Special, so his CP will be lower compared to a warrior. Also, SA levels affects CP a fair bit.
For comparison, my 3* 50/1 Slog is at 883 CP. My 3* 50/5 Jumpstream is 1190.
whatheheck
Oh.ya, my lvl 39 straxus is like 515 power only.
the difference between the 3,4* bots are really huge.
