Huawei Mate 10
CrispyPeddler
Use the in-app proxy to trigger the normal download, and let the phone download itself.
Flow
Press the proxy in app or something, it will install a VPN on your phone.
Just go and search for update as per normal from settings, will show you the available update, download and pause it once it's downloading.
Pull down your top bar, and disable your VPN.
Then resume download as per normal.
The VPN is to allow your phone to find the new firmware, but needs to be disabled prior to installation.
Sent from HUAWEI Mate 10 Pro using GAGT
woah. thanks!
but just a question, proxy in app is an app? and will this method mess with the phone if any steps goes wrong. like brick it:s13:
Wander
Hi all, I just got my huawei mate 10 non pro not long ago. I have encountered some wifi issues.. It seems unstable compared to other phones. Anyone facing similar issue? Usually will have to switch off and on wifi again after maybe 1-2hrs of using it.
OutBreak
No issue. You are using Singtel router?
Synchroniza
Been away from this thread for a long time..
Any m10pro SP or TG to recommend? My original one dmg coz I drop my phone on a sharp object heng screen no crack haha
CrispyPeddler
yea. in need of this also. normally which 1 to get? 9H anti fingerprint clear oleophobic etc etc
razo2004
My mate10 system update always show no update available... current is ALP-L29.8.0.0126. How to get it update to latest firmware. On singtel
Thkss!!!!
Shib
Thkss!!!!
Strange, I am on 132...
Sent from HUAWEI MATE 10 using GAGT
Moodee
I just got 1 black and 1 mocha M10 for myself and wife...any good M10 case to recommend?
I bought original Spigen from Tmall at only $12+.Sg is selling $23-30+?
【原装Spigen华为mate10pro手机壳软硅胶手机套保护套防摔外壳潮牌】http://m.tb.cn/h.3aIC3ru 点击链接,再选择浏览器打开;或復|制这条信息€m1FU0wULhGz€后到👉淘♂寳♀👈
Also,highly recommend this brand of anti glare glass screen protector - Carkoci. I use it on Mate 10,Samsung S9, One Plus etc for my family and it's fingerprint dust n scratch resistant. V good! $5+ for 2 pieces & cleaning kit
【卡古驰 华为mate10钢化膜p20p20pro全屏覆盖mate10pro蓝光手机膜】http://m.tb.cn/h.3aJwX8J 点击链接,再选择浏览器打开;或復|制这条信息€IGL60wULUkC€后到👉淘♂寳♀👈
Moodee
I highly recommend this brand of anti glare glass screen protector - Carkoci. I use it on Mate 10,Samsung S9, One Plus etc for my family and it's fingerprint dust n scratch resistant. V GOOD! Since I use this I hardly have to clean my screen. Can feel the difference vs my old one which I paid $10+ for at some ah being hp shop.. This taobao one is $5+ for 2 pieces & cleaning kit. You can read all the user reviews in the link below.
razo2004
Flow
Manage to download firmfinde but when go to in app proxy for download, it prompt need to set port to 8080...after set still no update show in the system update..advice???
Audiology93
【原装Spigen华为mate10pro手机壳软硅胶手机套保护套防摔外壳潮牌】http://m.tb.cn/h.3aIC3ru 点击链接,再选择浏览器打开;或復|制这条信息€m1FU0wULhGz€后到�淘♂寳♀�
【卡古驰 华为mate10钢化膜p20p20pro全屏覆盖mate10pro蓝光手机膜】http://m.tb.cn/h.3aJwX8J 点击链接,再选择浏览器打开;或復|制这条信息€IGL60wULUkC€后到�淘♂寳♀�
If don't wanna wait for 1-2 weeks, can consider getting it from casefactorie. Cheaper than retail. $19 for the Spigen rugged Armour.
I'm using this for Mate 10. The material on the back is super smooth but also abit slippery.
eyz
【m华为mate9手机壳mate 9全包软套meta边框mt9男mete创意mata9女潮】http://m.tb.cn/h.3asLIEf 点击链接,再选择浏览器打开;或復|制这条信息€zfiI0w6pokh€后到👉淘♂寳♀👈
this series grew on me.
super cute and reasonable thickness to withstand drop.
comes with free glass protector and lanyard.
got a few of it, and also matching ones for my wife mate 9.
KeYoKe
B138 firmware approved for mate 10 pro at huawei firmware finder
Added face unlock feature and may 2018 security patch
CrispyPeddler
【卡古驰 华为mate10钢化膜p20p20pro全屏覆盖mate10pro蓝光手机膜】http://m.tb.cn/h.3aJwX8J 点击链接,再选择浏览器打开;或復|制这条信息€IGL60wULUkC€后到��淘♂寳♀��
woah. looks good. thanks for the recommendation!
btw whats the diff with the sp violet and blue?
