Official OnePlus 6
deathst
As confirm, VoLTE is not supported by our 3 telcos for OnePlus model.
Sent from OnePlus ONEPLUS A6003 using GAGT
Oneplus must work with telco to register their devices.
Fellowes
Hi guys just got my OnePlus 6 from 131 express. Is this the same as you guys?
https://imgur.com/a/ceSeNqy
A6000 is China variant with Hydrogen OS, just flash over to OxygenOS rom will do, which I think what you already had.
A6003 is International variant with additional 3 more LTE bands, that the main difference in hardware. The latest build OxygenOS is 5.1.6.
Interestingly the security patch is still 1 May 2018 instead of using the latest patch from Google which is 1 June 2018 (maybe in the next update)
huangwn88
Is the difference significant?
Sent from OnePlus ONEPLUS A6000 using GAGT
Myu~sun
i think oneplus distro have to liaise with telco to enable volte for a6003 . maybe can check with distro . on imda website when i try search oneplus 6 it's not listed inside but distro got imda stick on their oneplus 6 =x tried oneplus 6 . one plus 6 . a6003 and even distro name also cannot find the info on imda website . weird . only oneplus 5t is listed on imda website .
jtec14
Dun think significant unless you need to use the phone in countries using that 3 additional bands.
For SG, LTE bands 3,7,8 are supported for both variants.
From gsmarena, look like the 3 additional bands are 30(2300), 32(1500) and 71(600).
https://www.gsmarena.com/oneplus_6-9109.php
deathst
Keep your phones physically secure! Don't lose them! To hand them out to anyone you do not trust. Don't plug to any untrusted sources!
Currently, Bootloader is completely exposed and reflashable with insecure boot images even without unlocking the bootloader.
This is a serious vulnerability as it allows an attacker with physical access to take control of the device. If the boot image is modified with insecure ADB and ADB as root by default, then an attacker with physical access will have total control over the device.
https://www.xda-developers.com/oneplus-6-bootloader-protection-exploit-physical-access/
tatsit
High Honorary Member
Any ways users can influence? I want to add A6000 too
Myu~sun
i think if they add will also add a6003 . dont think local distro will add a6000 which they don't carry . try facebook . seems hard to find their direct contact .
fevern0va
Oh... God......
garychengjw
not surprised coming from OnePlus :s13:
it's like the norms. :s22:
xRaewyn
First time using oneplus phone here..
Are most of you guys on a6000 or a6003? Currently on a6000 model will it have any impact?
tatsit
i believe most are on the global A6003 version.
no impact. but if the telcos decide to add the device into VoLTE compatible list, it will be A6003
GeSteSoh
Is there currently an auto OTA update on this??
mlwang
Wifi direct casting to TV for Netflix not working. Did not have the issue with Samsung Se7.
No problem with YouTube though.
Anyone having this issue?
