Hi
You'll need at least the ASET or Idealscope Image to assess light leakages of the diamond, if any. Without those, we can only go by the stats on the cert.
The HCA score is 2.4 for this diamond. By JP Super Ideal Cut standard, the HCA has to be 1.4 and below whilst it's advisable to only look at diamonds with HCA score 2 and below, that is if you are not too precise with the cut.
Crown Angle at 36.5 is steep, having a steeper crown can compensate for shallower pavilion angle 40.6 (which is the case here) but 36.5 is probably too steep. Ideal crown angle is 34-35. Hence, probably light leakages.
Depth at 62.8 is a little too deep, which means the diamond is a little bottom heavy, translating into smaller diamond face up.
Strong blue fluorescence, fair enough if having a "blue" diamond under sunlight is your kind of thing. Just have to make sure with the gemologist that the diamond is not milky/hazy. Usually diamond's value is impacted by the fluorescence, negatively. - good for you if you like it as it costs cheaper.
Carat 0.60 - flat weight, which is not ideal.
Color D - ok, but not necessary.
Clarity VS 1 - ok, but not necessary.
If you're looking to maximize your budget for a aesthetically attractive diamond in real life perspective, you can probably maximum the weight, get an ideal cut and go lower in color and clarity. (If you are prioritising paper stats, then this recommendation is not for you)
I'd think 3.5k SGD is a fair price to purchase that diamond.
hi everyone. am very new to this area and would like your help in determine how good is this diamond.
https://www.gia.edu/report-check?reportno=7288697452
how much would this diamond be worth?
How to tell based on specs if the diamond is shiny and attractive?
Thank you
