Official OnePlus 6
Skyy
Generally, all Wireless charging will get hot. It is physics in effect and this method is still inefficient thus why it makes a lot of heat. You could also say the same for Fast charging!
Dash fast charging not hot leh.
deathst
Ah that is where Dash charging wins. The heat is all in the charging brick, not the device.
One of the main benefits of Dash Charge (and VOOC (Voltage Open Loop Multi-step Constant-Current Charging) is the same tech used by OPPO and just rebranded Dash Charging for OnePlus.) is its ability to keep temperatures low while charging. The fast charging option allows you to watch videos or play games while the phone is charging, with no net drop in charging speeds. That isn't the case with Quick Charge, as the higher voltages invariably lead to the phone reverting to normal speeds to prevent overheating.
The dedicated circuitry in the charger itself for heat management and dissipation, which is why you can only get Dash Charge speeds with OnePlus-branded wall and car chargers — such as the one that's included in the OnePlus 6's box.
The key difference between the two fast charging technologies is that while Qualcomm uses higher voltages to charge batteries, VOOC relies on delivering a higher amperage. For instance, Quick Charge 3.0 goes up to 6.5V at 3A, creating 19.5W, whereas VOOC delivers 5V at 4A to attain 20W.
The main disadvantage with Dash Charge is that you need to use OnePlus-branded chargers to get the higher speeds on the OnePlus 6, as OPPO is yet to license the technology to third-party vendors.
tatsit
High Honorary Member
wow.. didnt know it's an OPPO proprietary
way_landr
Got a dbrand skin and kinda regret, it only overs the back and leaves the sides of the phone exposed. Main thing I want is to prevent scratches but now I still have to use a case for that.
Anyone used slickwrap before? Seems like theirs covers the sides
Sent from OnePlus ONEPLUS A6003 using GAGT
Kousoku
Anyone got the OOS 5.1.7 update already?
