Huawei Mate RS
chanbri
Did you put any protection for it. Looks like only your p20 has a case.
chanbri
Got link for screen protector? Are you using tempered glass?
Online seems can buy from Aliexpress. Others don’t have.
I am liking the size and the feel of this phone.
busfreaks
I bought the screen protector from Lazada but it does not cover the curve edge. Thinking of buying S9 flat screen protector instead.
the tempered glass protector will affect the flip case cover sensitivity due to its thickness.
bboyegg
i got my red Mate RS, but struggling so hard to find a screen protector in SG
nexusscion
Get the water based film instead of tamper glass. The glass one will loose your in screen finger print sensor.
chanbri
OK. Just checked and updated.
Sent from HUAWEI NEO-L29 using GAGT
bboyegg
Swee. Does the phone have the english language? Where did U buy this?
Yeah~it has english, i bought in Taiwan, a shop that sells oversea product, as the Red mate RS is not easy to get, i think it's only launched in China (as far as i know)
bboyegg
Red Mate RS unboxing
for those who are really interested in the Red Mate RS, here's my unboxing
http://egg3c.tw/?FID=1&CID=982
(sorry if you can't understand chinese, but you can at least enjoy the pictures)
busfreaks
now I am trying to find the water based screen protector. this time I ordered from ezbuy.sg hopefully it will. I bought 2 pcs from lazada but it is the glass type and does not cover the curve area. so upset
Kelvin0217
I bought the water based screen protector from this seller in Taobao. As compared to the various brands that I used on other phones, this is consider cheap and screen is smooth after applying. 3pcs for RMB41.80 and it cover the whole screen.
【华为mate RS手机膜maters保时捷钢化膜全屏覆盖防爆刮蓝光水凝膜】http://m.tb.cn/h.3bbaMyA 点击链接,再选择浏览器咑閞;或復·制这段描述€gBPB0CmlsyY€后到👉淘♂寳♀👈
