Got the 55x9000f. Any1 know if yas107 soundbar can sit in between the tv stands? Planning to get that soundbar if i can push it a little inside.
Im aware of this but I'm looking for a soundbar with integrated sub due to space constraint.Sony made a soundbar to match the 90F series...
https://www.sony.com.sg/electronics/sound-bars/ht-x9000f
I suggest that you get the dimensions of the sound bar you want to buy and also the space at which you want to place the sound bar. Then, compare and the wiring routing. This will clear out the myth and waiting for answers. I always do this method and get things going.Im aware of this but I'm looking for a soundbar with integrated sub due to space constraint.
Yes, I use the sony video player.. It does not recognise the sequence of the files and thus will not play, for example, a series of videos with numbered file names. So, I have to stop, go back to search and select the files and play them. Not ideal player but it works.Just wanna check if you guys using Sony default video player in the Sony TV to play 4K media content from your USB drive?
Sent from Samsung SM-N950F using GAGT
你嘅MIO機頂盒如果輸出1080i高清畫面,就要睇你電視影像處理器有無2k畫像提升(upsaling)至4k畫面功能嘍。。。Any difference when watching soccer on miotv box on x8500f and x9000f?
FHD - 43W800F S$999 or 4k /UHD - 43X8500F S$1,349 all at best denki.I’m considering to buy either a smart TV or android tv but don’t know which is better. If Sony android tv, should I go for W800F or 8000e series? Mainly only use for watching dramas in my room, 43 inch. Any advice?
Has anyone managed to get the Google Chrome to work on the Sony Android TV. Tried a few methods shown in you tube, but cant seem to be able to use it, although I can see the app in the main TV menu. any help will be appreciated
what exact problem are you facing ? I have been using Chrome browser with my sony Anrdoid TV for more than 2 years..
