[OFFICIAL] Fish keeping lover lounge
ZedMaster
what kind of soil to grow plants in? or use sand?
Soil not so important. If you ask me, better to use cheap brand soil. High nutrient soil may cause other unwanted issues, like algae bloom at the initial stage of the tank.
What's more important is the balancing the quality of water, filtration and amount of lightings.
Those $1 aquatic plants you spoke about is useful for early stages coz that's when you have plenty of nutrients in the tank and those plants suck up lots of it. That's why they grow really fast, a nuisance. I prefer slow growing plants, like Nana or Anubias, and watch it grow every day. That's the enjoyment for me.
I have done a planted tank without any soil also. Still looks beautiful if you know how to set it up.
tankgunner
Mentor
if I put a brand new filter and let it run in a mature tank, how long it takes for the BB to be ready for this new filter?
Mila Azul
At least 1 week? or you can simply move your old/dirty filter over to the new tank or just buy a betta put it in the new tank it will also help to speed up the cycling process
Ammonia(cre8 from uneaten food, poo, dead plants etc) is like food to the BB
when i accidentally switch off my filter i will use nitrifying bacteria it takes about 1 week to fully cycle my 4ft tank, how i know whether it successful is the smell, BB all the died the tank will have a foul smell after adding the nitrifying bacteria about 1 week the smell is gone
Mila Azul
Cheap plants dont auto equal easy plants....
Dont have to get expensive soil as they will useless in a year or two. DIY root tab and ur good to go. Cheapest way
Yah use diy root tab
Not my pix
wixxxx
not all plants need soil or base fert.
you need to know what you are growing.
Not my pix
Noted......maybe put cheap sand for decorative purpose but add root tabs....want to focus on fish keeping not gardening too :s13::s13:
many thks for advice
Nemesismaster
I think all filter types have their pros and cons. Really depends on filtration need of the aquarium, aesthetics and practicality of maintenance.
Canister has good filtration capacity but maintenance is more complicated. Not to mention, canister is also more expensive.
Sent from Samsung SM-G955F using GAGT
Bro, for my 2 teir canisters, I used all B.B cultivation . The inlet in the tank I use sponge filter. Every 6 months I only open the canister once to change the foam on top of the canister. Inside quite clean despite 6 months never touch.
No hassle one bro. Just don’t follow the traditional method of canister first top teir filter and 2 teir BB cultivation . U will just dirty it very fast especially ur fish is slow eaters.
Nemesismaster
The pro of canister is clean looking tank . When washing tank for few hours bb not disturbed. Well circulation of tank water no blind spots provided u used the right filter speed 5 times per hour rule applied . Ironically hassle/ maintenance free.
Con is electricity. For me I cannot tell the difference in bills when I don’t use cannister at all the whole month lol
Good filtration and water health for your fish. I put as con because Some fish I don’t like grow bigger and bigger and never seems to die ^^ in fact I have over 30 fishes at one time n no casualties for 1 whole year!
Unless u are keeping shrimps and guppies then no point going canister if not be a little committed, use a good filtration system n WC every week!
ljohn78
Thats actually true and quite smart. How often do you clean the external foam filter? Also may i know the type and brand of external foam filter you using? Maybe a picture for illustration would be great. Thanks.
Nemesismaster
Thanks I learnt through the trouble some hard way bro .
The sponge filter I use is ehiem brand. It has a solid casing that holds your sponge and connect to the canister inlet. Get 1 more pair of sponge so that when u WC clean n squeeze those in dirty tank water. Leave the wet one aside and rotate to use the 2nd pair. This way for ages, your sponge will always feel firm n not soggy.
skytan13
Actually I tried before it is not really that fantastic
But it is confirm a upgrade over the old sponge filter , I replace mine with left over seachem media .
I bought the basic for $35 at seaview taiwan selling it for less than $17...
skytan13
Substrate , I use Amazonia also .
Why , just the system is tried and tested so follow accordingly abit dummy proof.
It’s expensive the bad part .
Mila Azul
Actually the wuwu part it's normal leh the original package also can make the poop wuwu
my k1
Newbie12
Hi all
I am new. I have a 3ft x1.5 x1.5 tank. Abt 50 gallon. Is a ehiem 2213 sufficient? I bought it by mistake cos I Thot my tank is 30g.
It's a fresh water planted aquarium with some fish.
skytan13
Not really , but planted have a little bit more leeway . See ur bioload bah probably no issue just need to clean it more often else can add a hang on
Hi all
