Building a gaming rig
Mohd saif
hello, this is what I have in mind:
i5-8400
ASRock b360 pro
8 gb ram
1 tb hdd & 120 ssd
1060 6gb / 1070
500W
Still need monitor, windows and such..
Budget around 1.6-1.7
Ty!
singupingu
What kind of games are you playing with the rig?
This budget and needing a full setup, you cannot go with fancy parts just so you know
Sent from OnePlus ONEPLUS A3003 using GAGT
Mohd saif
Not looking into fancy parts. Good performances can already.
Looking to play RuneScape only at max (not interested in other games now or near future)
ZrE0_Cha0s
given the game u playing, i still think that amd ryzen 3/5 should be more than enough and u pobably wont need a gpu.
Mohd saif
GPU is needed uh as the client itself was designed to be used with dedicated graphic cards
ZrE0_Cha0s
What I meant is that with r3 a2200g or r5 a2400g. Their iGPU is more than enough to power up your game.
singupingu
Does it run on max aswell?
Nope it can't max with Ryzen 2200G.
I'll suggest the following based on your preference though:-
CHASSIS: Fractal Design Focus ATX ($75)
MOBO+CPU: Asrock B360 Pro4 + Intel i5-8400 ($392)
CPU HSF: Cooler Master Hyper 212 LED ($39)
RAM: G.Skill Ripjaw V 2666MHz 2x4GB ($148)
PSU: EVGA BV-500 80+ Bronze ($79)
SSD: Transcend SSD220S 240GB ($85 via Lazada)
HDD: Toshiba 1TB ($53)
GPU: Zotac GTX 1060 6GB AMP Edition ($418 via Lazada)
MONITOR: Samsung S24F350FHE 1080p 60Hz PLS panel ($168 via Lazada)
OS: Windows 10 Home (source yourself. Install via Windows Creation Tool downloaded OFFICIALLY from Microsoft site, created into a 8GB (or bigger) thumb drive)
TOTAL: $1457
Remaining budget: $243 for keyboard, mouse, speakers/headset of your choice
Prices quoted from PC Themes or otherwise stated.
Prices above are SRP and it's not subjected to any kind of discount yet.
Online prices are based on the time of posting. Best to have credit card to use certain credit card discount codes weekly, earn points and cashback offered by your credit card.
Mohd saif
I’m not planning on building it myself so I might have to buy full parts from SLS. Do you think I should buy half half and let PCT to assemble?
singupingu
Of coz you can.
My suggestion is to bring the SSD there only. Then GPU you install at home, install the drivers yourself. That will be easier.
Not very good to bring major components you source outside and ask the shop (which never sell you said component) to install for you.
Hence, I suggest just the SSD only you ask them install won't make you look that bad.
singupingu
Runscape system spec so heavy meh?
Apparently there's a Runescape 2018 lol
Plus, TS wanted a certain range of specs with a decent budget. So I'm just recommending based on his needs and wants. Also, i5, gtx 1060 6gb with full HD 60hz monitor can run almost everything he wanna try, even newer AAA titles at high settings if he want.
ZrE0_Cha0s
eh....runescape such a old game still got remake a 2018?
ya, i get what u coming from. getting a new PC and hope that it last for another 5 years or so for the games. even though maybe abit overkill on it. :o
singupingu
I can't promise a 5 years specs overkill. It looks good for 3 years through, provided AMD don't come out with killer GPU like the Ryzen on CPU section. Not that I support anti-competitive. I speculate based on current market trend that's all.
Anyway, it's not overkill at all. Maybe yes for runescape, but TS is unsure too whether the PC will try other stuff. But his request on i5-8400 and a capable GPU choice of gtx 1060 6gb or GTX 1070 is fulfilled. Didn't chose 1070, coz otherwise he will need to seek out 2nd hand components and a 60hz full HD is underwhelming too. Given the budget, gtx 1060 6gb with the mentioned monitor is a more balanced and adequate combo.
olddude
Amazon Prime having a Prime sale on the 16th of July.
Can grab some of the parts there.
ZrE0_Cha0s
The new client, NXT, if you want to play at ultra~ , these are the recommended specs by the mods. At least 1060 6gb,i3/i5..
u meant this one:
Baseline Ultra+ PC
Processor: 4th Gen or Higher Core i5 (Quad core) or higher (Or the AMD Ryzen Equivalent)
Graphics: GTX 1060 3GB/ RX480 4GB
RAM: 8GBs of RAM
Detail: Ultra
Price tag: ~$700
seems like this new gaming engine might be using direct X system though.
okay, seems like cant find their actual specs or what kind of specs they require :p
