2018 Macbook Pros launched
Snoweagle
Does anyone know if the new sleeves and leather case will fit the 2015 MBP, or only the new ones with TB?
htngwilliam
Likely a new MacBook Air variant is possible. If not then a Mac mini? Typically they can’t launch anything more solid than MacBook Pro. Imagine a MacBook Air with touch screen appear. Everyone sure kaopaykaobu
szeli
Craig has mentioned many times there won’t be a touch screen Mac.
TrueBeliever_jh
think only the TB versions.
the dimensions are very different. you can see the video, the person got a hard time fitting his MBP into the sleeve, can tell how tightly fitted it is for the TB version.
TrueBeliever_jh
yeah it's already out le.
iPad Pro + Smart keyboard :crazy:
htngwilliam
Initially I am thinking of a MacBook Air variant with gen 8 CPU costing $1499. Lol! Then swee swee liao
TrueBeliever_jh
think not everyone wanna go down to Orchard road to take a look at the new model.
but here's the thing. the model is exactly the same as last year's.
and one thing is that if you choose the base model, you can probably buy directly. no need to wait for delivery.
Chevalier
Personally I've always enjoyed the buying experience at the applestore
TrueBeliever_jh
Chevalier
hmm.. looks identical. i am actually aiming for this instead
Satechi Aluminum Multi-Port Adapter V2
the problem is the power is only 49W.. so i don't whether is good enough.
i think it ll charge slower.
the 13"models uses a 61w charger whilst the 15"uses 87w charger.
however, u still have 3 other ports to plug ur charger into so its no problem la.....lol
derrickgoh
Hope the belkin usb c gigabit dongle works. Some review on apple store claim got issues.
