- Jun 20, 2007
If you buy from qoo10 finer, the tempered glass is free gift. I also have it even i didn't buy it
I can't answer your question with certainty as I have not tried to install ALL the apps in the Google playstore. All I can say is most of those I tried to install managed to get installed. Among those apps I install is taobao, lazada, qoo10, whiteboard, kindle reader, chrome and qq games etc. Quite a lot of them say it is not optimised for your device aka it is phone version.
The only app I tried to install and fail is Aliwangwang (the chat app for taobao).
Actually I think the screen protector was outside the box... I think my reseller included by mistake?
Oh... that's nice to hear...
I'm using Olive Tree Bible, You Version Bible, Microsoft Office Mobile mainly... hope these work well... some games like Asphalt Extreme, Tetris (EA version), Wordalot, etc...
Where to buy Mipad 4 with sim card slot in SG ah? Can some bros recommend?
Found all the apps you listed weren't listed as " Your device is not compatible"... aka should be working fine.
Iirc some one indicated It's not out in the market yet.
Is the cheapest export set $255 ?
$23X for 3/32 and $25X for 4/64Is the cheapest export set $255 ?
Sent from HUAWEI MATE 10 using GAGT
Not too sure about this, but Mi pad 1 had global rom, but Mi pad 2 and 3 did not. So I'm gonna have to assume that there's no global rom for Mi pad 4 unless they plan to sell it in India or HK.This is really attractive if it comes with a Global ROM... my understanding is that the MiPad is a China-only device right? So no chance of a Global ROM?
swiftkey user, typing / swiping ... like hot knives into butter.Has anyone used this MiPad 4 for typing? I usually take minutes using a tablet. I touch type on my Sony Xperia Z 10.1 inch (since 2014) and it's kind of a bit laggy now... anyone has experience doing touch typing on the MiPad 4? Is it decent? I know 8 inches is a bit small, but I'm looking to downsize. 8 inch tablets can be so much lighter and so much more compact...
mipad 1 comes with micro sd card slot. with global rom too . . .Hope got Global ROM. I remember not buying the MiPad 1 cos it didn't have removable storage and the higher storage options were quite expensive. Subsequent MiPad 2 & 3 didn't have Global ROM and hence no Playstore by default, which in my experience meant that you couldn't install certain games or apps cos the list of compatible devices weren't in that game profile. But it seems that Xiaomi has worked around this problem since michael_thm doesn't seem to have encountered this issue... but I think Global ROM will be better...
Sent from LG G6 using GAGT
I paid $230 for the lowest spec one
