bluedubsBB
- Jun 21, 2015
Quiet down Liao. Did u all stealth hoot or move on to other phones Liao ?![]()
No leh, I subscribe to your channel, but no daily update on your user experience on U12+ leh
No leh, I subscribe to your channel, but no daily update on your user experience on U12+ leh![]()
Haha, I thought I provided long updates Liao mAh
Use for about 4 days Liao
So far so good
Some small issues:
1)Camera sometimes takes long time to load
2 )Brightnessadjustment sometimes takes some time when you go from your pocket to outside
3) your squeeze sensitivity needs to be tuned accordingly if you have a case
4) phone is quite large with a case.
Other than that, no issues with u12+ so far
So torn between U11+ and U12+ after your mini reviews
ofcos 12+ la, bigger screen![]()
Actually both are quite similar. Only difference is the virtual buttons and twin camera on the u12+ plus newer chipset
Stealth bai, bai from eBay
Size wise. Quite similar but I using poetic case which makes it a little bigger
No one cares for htc low and mid range. Overshadowed by Xiaomi, Nokia and Honor.HTC has silently released the Desire 12 and 12+ in Singapore. Perhaps we can see the U12+ arriving soon too.
How is the battery like?
Very good. Easily last whole day without issue
Also depends on your usage bah. I mainly is surf internet and WhatsApp. Some youtubing . No gaming
