Digital TV (DVB T2) Consolidated thread V
kssk88
Got this under S$30 for friend. No antenna yet but can receive some.
Later going to help set up with their existing antenna.
Sent from SomeWhereUpThere using GAGT
Hi,
I got your pictured universal remote control but unable to set up.
May I know is there any instruction manual for the remote itself.
Also The seller asked to press the "SET" with "Power" which "Set" is not found. I tried other buttons like "OK" or "TV" and none works.
If convenient can you upload the instructions here.
Thanks in advance.
albertlee
Hi,
Thanks in advance.
Not sure if you're referring to this "universal" remote control meant for STB replacement. Refer to the link below:
https://www.aliexpress.com/item/UNI...atellite-television-receiver/32789248242.html
xdivider
Just tried, courts can't redeem Funke 5.1. Only Funke 250.
Sent from HUAWEI MHA-L29 using GAGT
i went courts somerset, they okayed it....
may be possible they dun have the compatible list from website and only used the one u linked. trying showing them the other list.......
albertlee
Probably no stock for Combo 5.1 at certain store, don't see any reason they would refuse a sales!
YoYoMa88
Hi,
Thanks in advance.
Got pic to share?
My setup was done within 5 mins.
GReddy G9 RS
Maybe you should show them the IMDA list too. :s12:
Show them the lists liao, the salesman said their is the latest. He said tried to scan over the weekend but cannot so i walk around then go back n ask them to try and can so the salesman apology They have a lot of stock at Toa Payoh Courts.
xdivider
try sommerset......
kssk88
That list sure covers most of the designs out there
Can't really find one which matches mine(could be due to poor eyesight)
One distinction is my first row the 2 buttons next to Power are un-marked,
Went back and tried pressing it anyway, still no light.
This is the type I have
https://www.ebay.com/itm/Best-Unive...-au/192494446149?_trksid=p2485497.m4902.l9144
albertlee
You brought this to replace/supersedes which STB remote?
Not sure what light you're referring to as there is no indicator light on the remote. And the transmitter end doesn't emit visible light!
The remote which I provided you the link has a small indicator light beside the DVB power button.
In short, think you got the wrong "universal" remote!
xdivider
After i insist they try to scan again then can. At first they said over the weekend they tried also cannot.
i juz walk in ask the guy 5.1 can buy 2 with letter, he said yes......
GReddy G9 RS
I was there at about 11 plus am today. Maybe after my incident that they realise. Before that they keep showing me the list they had.
