Xiaomi Redmi Note 5
KWSquare
Anyone waiting for 128GB?
Sent from Xiaomi REDMI NOTE 3 using GAGT
I'm tempted to get the 128gb, probably will just buy it off Taobao.
I think the Qoo10 retailers aren't bringing in the 128gb, if they were to do that, who is going to buy the 64gb/6gb sku?
Sent from Xiaomi REDMI NOTE 5 using GAGT
RLWZ21
Probably they will bring a few of both.
Sambuca78
Sometimes the location status show off in the dropdown menu but when you look into the location settings it is on. :(
Anyone face the same issue or know how to resolve this? Thanks.
garychengjw
V9.5.19.0 which is anti roll back version.
Let's say I've China rom note 5, which global rom it safe to flash?
Ordered a red note 5, want to flash to global rom.
Sent from Asus Zenfone Max Pro M1 using GAGT
Just Me
where to get this phone at cheapest price?
Since the fake rom issue can be rectified without opening up the set, I would suggest JTBC shoppe. 3/32 at 195 and 4/64 at 239 for export set and if you're not in a hurry
Hotsnow
The set i bought is in Global rom, after phone setup completed it auto prompted for update.
Sorry not sure about those China rom, hope some expert can verify.
silverstar
it really depends on the antirollback version of the rom you get.
http://en.miui.com/thread-3156438-1-1.html
if arb3 (b4 the antirollback versions), then its pretty safe to flash anything. once you hit arb4 (with antirollback) you need to be careful, in case the wrong version bricks your phone.
how to check arb version and other faq
https://forum.xda-developers.com/redmi-note-5-pro/how-to/faq-questions-answered-t3816185
