2018 iPad Pro
watzup_ken
Microsoft lauched the Surface Go.... lol man. Trying to fight ipad. Zzzzz
Observing their consistent severe quality issues on their Surface products, it is best to steer clear from MS Surface.
Anyway, the Surface Go is not exactly cheap since potential buyers will need to consider buying a keyboard as well since Win 10 is nowhere near touch friendly as iOS.
Snoweagle
Check Lazada. The 1.2K deal is back for the Rose Gold 512GB iPad Pro.
Search for "Apple iPad Pro 10.5-inch Wi-Fi Rose Gold 512GB".
That’s a very good price though, mine’s also rose gold, except it’s wifi 64GB. But I don’t put a lot of things inside my iPad, except a few games, some apps and some photos. I haven’t even used half the capacity, currently at 20.3GB.
Bryson
I’m using Pixelmator Pro. I’m not a pro photo editor, but so far it’s able to do what I needed.
Thanks shall look into it as well. Found another app called affinity photo? Apparently it is highly rated too.
Bryson
Just to side-track a little. I typically wouldn't edit photos on my iPad, so using Adobe Ps/Lr on my MBP instead.
If you can wait a while longer, Adobe's releasing the Ps Express for the iPad soon.
I believe they’ll require subscription fees again?
watzup_ken
This is a very expensive app. Have the non pro version though. If only they allow upgrades instead of re buying it.
I bought it when it was on sale. I can't remember, but I think it was 50% off then. I don't know how powerful it is for photo editing as I don't use it extensively. But if it can do what you need, I don't think it is as expensive as Adobe.
GotBetrayed
Tiagong Apple registered new iPads with EEC, means the new ipad pros gonna launch soon. The Apple education sale is to clear old stock. If can wait then wait, don’t buy now.
my6600
I also plan to buy one if it is a new radical change.
8-9" full screen is the best liao (ipad mini but full screen-body ratio) :D
https://buyersguide.macrumors.com/#10-5-iPad-Pro
Caution - 347 days with no refresh.
Latest report says 11" ipad pro, let see.
same thought. ipad mini the size is perfect, if there is a bezelless model of it, it will be super cool. the current 10.5 or 12.9 the body size are just too big to bring around.
the current ipad pro are really just transition products.
GotBetrayed
Usually after registration is how long?
2-3 months I think. Register means the device more or less already completed. Registered as iOS 11 devices but we know iOS 12 is coming sept. So basically I think they wanna launch new pros with iOS 12. For processor think will be a11x or a12/a12x
rvyne7
any news when this new iPad Pro coming? :p I still need a good manga reader... tempted hard last weekends after seeing cheaper laminated service for iPad at sim lim seems fit style for my next iPad (sleeve and naked)
GotBetrayed
Should be September. Already got supply chain leaks and design leaks
watzup_ken
Clearing stock Liao to prepare for new model launch.
I bit the bullet and purchased the iPad Pro WIFI with 512GB of storage. It was going for 1150+ before any discount and LiveUp rebate on Lazada. Likely clearing stock, but hearing some of the rumors floating around where the finger print scanner and headphone jack will be removed from the new iPad Pro models this year, I don't think I will be interested.
I feel the removal of the finger print scanner is an issue for a tablet that I share with my wife since I believe one of the limitation of Face ID is that it only recognizes one face.
watzup_ken
Buying an iPad Pro to read manga is an overkill to be honest. :s22:
Carnage
Just input passcode.
