Water heater
kevinlaikf
Is there a good instant heater which could last over 5 years? i bought my "M"-brand heater in 2012, lasted till 2015 before it flooded the internal compartment before reaching the live electrical connections. Discovered when my kids told me about the leak. The 2 thin valve plastic pipes harden and broke and slow gradual compartment flooding when inlet pipe was turned on. Close Shave, potentially fatal to my teenager kids. Today, same thing happened to the replaced unit. just 3 years in use, Given up hope on this M brand. I don't think its coincidentally same fault, it must be poor thermal-resistant material or design issue.
My mistake to be lazy to buy same model to save the trouble to drill new mounting holes.
Now i need good proven solution.
kyteo79
These day many items fail on 3-5-7 mark. same for car where "seems" programmed to die overheat at 80,000 mark and so ..
Anyway, take it easy and choose value for money products where it can last you effectively for maybe abit longer ?
kero89
Go to their showroom look for amanda..
Nice showroom, product knowledge good, special price for BTO and most inportant is good fast neat and ontime installation.
Hi! your piping done by aos as well? Is it separately charged?
djr81
All in... they do all the piping.. if need to go to kitcher mixer i think there will be addition charger.. maybe u can check with amanda...
djr81
She should in office most of the time.. if u wan maybe u can call the office before heading down...
If not can just go direct to the showroom and see the water heater the sales team should be able to anawer all your doubts..
Do remember to ask whether got bto group buy if yours is a new bto flat.
How do I contact Amanda to check if she's in before heading over?
Ark Law
Can try Panasonic lorh. Cheap and cheerful.
victorkk
I have a Joven heater storage like 1.5y, now cannot heat anymore. Light on the switch comes on but the light on the tank does not come on. Called Joven and was told that repair cost will be $200ish for heater replacement, transport and labour. Think not worth to repair.
Anyone got suggestion?
IAmZlatan
Just purchased a 40l digital heater from AOS Bath for my flat.
Amanda was busy so I was served by another lady. No better price though.. Oh well..
kyteo79
next is what rain shower system u need and remember get contractor to liaiase direct with AOS on installation .. route the water to washing machine and taps ..
kyteo79
spoil faster change ...
friend heater dropped after mini explosion ... lucky no injuries
IAmZlatan
Hmmm? I'm using for the toilet showers only.
Bought Kohler rain shower already
Aw2006
Totally same problem with me. Plastic tubing will eventually become brittle and corrode. You can just change tubing if you can find.
I changed mine to trentios. $60 from qoo10. No plastic tubing. Totally satisfied
