Damn, drop my sandstone oneplus 5t and there's a deep scratch on the bottom edge. Wonder if it's worth it to replace a new cover?
the case scratch or the main phone's metal case?
Sent from OnePlus 5Teh using GAGT
To be more precise, it's the battery cover.
ouch. Well it is quite easy to replace the back metal as its just a pop up and not glued together.
I accidentally poured a hot cup of tea over my OP5T, will my phone be ok? I picked it up like 2 secs later.
I guess only you can answer that questionI accidentally poured a hot cup of tea over my OP5T, will my phone be ok? I picked it up like 2 secs later.
Sent from OnePlus 5T using GAGT
I’m actually still on 3T, where can buy the 3 pin plug charger for dash charging?
Are you looking to let go the original cable?I actually have not used the original cable that came with the phone as I find it too short. I bought a 1.5M dash cable when I first bought the phone and has been using it ever since.
Are you looking to let go the original cable?![]()
Just to update that I contacted oneplus local service centre, they say they don't have spare parts to replace white sandstone battery cover.
It also took them 2 working days to tell me that. Bad customer experience.
Your mail box full.
You might be interested, 3pin oneplus dash charging plug at good price 15.30
Based on review, seems authentic
https://www.qoo10.sg/item/ONEPLUS-O...L-CHARGER-ADAPTER/625195860?banner_no=1305330
Non referral link.
yours local set?
