Oneplus 5T
jinsong
Damn, drop my sandstone oneplus 5t and there's a deep scratch on the bottom edge. Wonder if it's worth it to replace a new cover?
Eddied
ouch. Well it is quite easy to replace the back metal as its just a pop up and not glued together.
Sent from OnePlus 5Teh using GAGT
i tried with those prying tools also damn hard to remove :s22:
lousydrinker
I accidentally poured a hot cup of tea over my OP5T, will my phone be ok? I picked it up like 2 secs later.
jinsong
I see the YouTube video like not easy. Anyway, any idea how much it cost to replace sandstone back cover?
Eddied
there's not waterproof certification but youtubers have tested it to be pretty resistant to water so most probably it will be fine
rollanddie
I actually have not used the original cable that came with the phone as I find it too short. I bought a 1.5M dash cable when I first bought the phone and has been using it ever since.
Are you looking to let go the original cable? :o
jinsong
Just to update that I contacted oneplus local service centre, they say they don't have spare parts to replace white sandstone battery cover.
It also took them 2 working days to tell me that. Bad customer experience.
tiancaiz
yours local set?
