Apple Watch 3 LTE
tec_geek
Starting to see the additional 0.3GB or 300MB from the NumberShare subscription being reflected in the Singtel app.
LIN_JOEL
Advice needed.
Just dropped and cracked my iPhone 6 screen.
Think I'll wait out for the new models in Oct.
Just wondering if I'm gonna use a Android phone temporary ..
1. My Singtel Numbershare would still work?
2. Using Strava on my AW during my runs, and syncing it done once i back home to the iPhone. Does it mean i cant sync it with the Android phone once i return from my runs?
3. I guess Apple health is out of the picture totally.
If you are not using and pair with iPhone, battery dry very fast.
Even it work but it's troublesome to keep charging on the move.
williamgohsg
Do you guys support the apple watch strap copies? (I know it is not good to do so) but what do you guys think of the quality?
tec_geek
It depends from band to band and the material of it. I’m currently using a black coloured third party Milanese loop.
Works and feels great (to me). No issues encountered so far and looks just like the one from Apple and there isn’t any major issues, just the quality of them as compared to Apple’s, similar for other bands as well.
For sport band wise, since it’s more for rugged use, might want to consider the one from Apple?
Snoweagle
Singtel, after the MySingtel app upgrade to include the "0.29GB" into our data, the whole data was reset and up to now it's not fixed.
williamgohsg
Thanks Tec Geek! Great input and will certainly try that. Appreciate your advice. :)
Kyubi
i got one also.. but when trying to slot the strap into the watch.. the feeling is so different from putting on a genuine strap.. scare spoil it.. lol
itsmee
Just got my nike 3, LTE. Duno wanna use or sell and buy apple watch 4. I read that LTE for apple watch very data consuming? Any bros using LTE can share.
crobin
Depends on your use case. For me LTE comes in during gym time so I can receive messages or calls without me having to bring my phone around. Since it’s mainly text messages it’s really very little data. Battery not much impact
Kanton
Hi all,
Just whated to check with those who hase the series 4 with cellular, are you able to use your whatsapp if you don bring your phone along?
tamago_
Deluxe Member
You can reply to Whatsapp messages through voice-to-text, if Whatsapp notifications are enabled on your Watch.
twosix
Quite frustrated with the watch. do you get delayed notification on the watch? ie, the phone already receives the notification, eg. ibanking pin, but it will only show up on the watch several seconds or minute later, making the notification useless.
when i was using the garmin fenix, the notification actually showed up same time or even faster than the phone.
how to improve this?
