XZ2 Premium
omelet
Hi all, just to check does the default charger have quickcharge ?
The XZ2P comes with a 3-pin SG/UK UCH20 non-quick charge charger.
If you need QC3 can get the UCH12 charger, however they still selling the 2-pin model.
If you need 3-pin can get the WCH20 wireless charger which actually comes with a 3-pin UCH12 charger.
Sent from Sony H8166 using GAGT
boaboy
Ok noted, no wonder it charges so slow. Thanks a lot for the info :)
rssd21
One thing to note is that faster charging rates will wear batteries down at faster rate too, in the long term.
In short, the battery capacity loss will be faster and naturally leads to faster draining of battery that was charged at higher rates.
The difference in battery capacity will be evident for long term usage.
But it should not be significant for those changing phone or the battery every year or less.
boaboy
Those who looking for tempered glass and casing, you can refer to my earlier post or look for MobileLite.
Just met mobilelite for my full screen tempered glass. Smooth and excellent quality. Oso bought a black case. Feeling happy now :)
SeanPC
so good. the free wireless charger came with qc3 charger. i thought is the same as the charger that came with the hp. it charges slightly faster.
carlover76
Glad that you bought the XZ2 Premium as well as the tempered glass and casing from MobileLite.
His product quality is better than those selling outside for sure which I tried before too so will stick to his product.
carlover76
Ya. I bought the wireless charger from Sony when I get my XZ2 premium too. It is also cheaper and better than the Lagsung wireless charger!
jt2901
Eh, not free la. Just discounted when you preorder. Not sure if you get a discount when you buy xz2p now
boaboy
The wireless charger is good and worth it. Got it at a good price from a seller at carousell.
