Xiaomi MIPAD 4
Hotsnow
Finer sells the 32gb for 225 after 30 discount but overall cheaper than other sellers for the 64gb version
Finer frequently promo for 3/32GB wifi at 199, free TGSP.
Extremme
I understand it supports sd card but since andriod cannot allow the transfer of apps onto sd card, it's really just to store photos and videos etc right?
s1mple
Anyone installed Google Map? Somehow my Google Map is unresponsive. Dont know what the issue is.
Just Me
Mipad 4 has no GPS unless you are using the LTE version
gerald27
unresponsive as in?
do you mean it doesn't point to your current location when you try?
Just Me
JTBC has it. Add $90 for 64G version. However I do not the set has a real global ROM.
If it's the 4/64 version might as well buy from finer
Just Me
Not sure why JTBC advertised in Qoo10 as global ROM. Anyone can confirm it?
No global rom for mipad 4 yet. Sellers like to use the term global rom to indicate that play store is included
allanzzz
edit: need to grant permission to many Google apps. finally able to sync contacts.
