Xiaomi MIPAD 4
ktinos
Bought the ANC Type C headphones on impulse without checking. Dun seem to work, plus type c to USB dun seem to detect my dragonfly red. Anyone had any luck?
Sent from Xiaomi MI PAD 4 using GAGT
Audiology93
Not sure why JTBC advertised in Qoo10 as global ROM. Anyone can confirm it?
Either fake rom or they just installed play store to it.
My guess is that the USB c port is for charging only and does not support audio/data out.
Sent from Xiaomi MI 8 using GAGT
tessss
Saw a review mentioning that the mipad 4 can also use to charge other devices. Maybe thats why?
Saw this in xda, this who want can try. I only got the wifi version.
The calling feature is not present in the tablet.
There is a reason there is no phone app in the system, and the only way you can call is through VoLTE and you have to check with your carrier if thats available for you.
In MIUI thread people have VoLTE calling enabled in china using their carriers, so you have to check if your carrier supports it,
If your carrier has VoLTE support but you still cant use it then:
1)Go to settings
2)go to storage
3)tap on total storage until you see a prompt
4)You can make a call by opening the configured VoLTE/video call/WLAN call option
5)Or you can use whatever app you use to make the VoLTE call and try it
Dont forget to hit the like button
https://forum.xda-developers.com/mi-pad-4/how-to/enable-volte-device-calling-t3838408
cscs3
Like that has to hold on to purchase. Never like to have China ROM.
cscs3
1)Go to settings
2)go to storage
Dont think this is VoLTE calling but calling via data plan with supported application like wechat (or whatsapp).
flingstar
Just got the pad and when charging I can feel electricity running at the back of the device. Is this normal or faulty?
megaweb
Anyone installed Google Map? Somehow my Google Map is unresponsive. Dont know what the issue is.
I just installed Google map app on wifi version, no issue. I can get my location when connect to Internet.
Sidler
It will happens if the charger is two pin type without earthing.
Which handphone charger have real earth?
Earth pin is plastic for the chargers that I can remember.
Even those charger with multiports only accept a 2 pin input.
cscs3
So far never seen one has a real earth pin.
Sidler
Hooted a Mi pad 4 plus at 397 with the $50 dollar voucher. Thought the retail is $380, so pay abit more for the shipping sounds reasonable.
